I'm having a weird problem with my wife's 2011 XC90 3.2 with 131k mi. Recently the vehicle started making a high pitched whine when idling or when the throttle is closed. The engine seems to idle a bit rougher too and I am getting a few error codes:
ECM-P017100 System Too Lean (Bank 1)
ECM-P017400 System Too Lean (Bank 2)
ECM-P042000 Catalyst System Efficiency Below Threshold (Bank 1)
This one just appeared today:
ECM-P227200 O2 Sensor Stuck Lean - Bank 2, Sensor 2
For the first two, the diagnostic info suggested a vacuum leak so this weekend after changing the oil I tried visually inspecting the hoses and fittings, spraying soapy water on the connections and listening to various components with a long hose held to my ear, but couldn't find anything. The whole intake sounds about the same. The noise might have been louder around the two actuators on the intake manifold, but I'm not really sure.
Not sure what else to do, I tried the glove test and when I started the engine the glove was quickly sucked against the screen in the oil filler. I was actually worried it might get sucked in and the glove ripped while I was trying to remove it while the engine was still running.
I have vida/dice and tried clearing the codes, but they come right back. The slight roughness at idle is consistent, but the high pitched noise only seems to occur after the vehicle has been running for ~20 min or more. Today when the noise occurred I tried removing the oil filler cap and could turn it, but there was too much vacuum and I could not pull the cap off (when the engine is not making the high pitched noise I can easily remove the oil filler cap). If I pull out the dipstick that seems to let enough air into the crankcase and I can then remove the oil filler cap. Removing the dipstick or oil filler cap also makes the noise go away. Is it possible to have too much vacuum in the PCV system?
When the system is making the high pitched noise, shutting off the engine makes the noise fade after a few seconds. It doesn't immediately stop when the engine stops.
One other odd thing is that when the engine is idling if I tap the accelerator I can hear a brief pffft kind of sound coming from somewhere in the engine/intake area. Maybe this is normal, but I hadn't noticed it before today.
