Love the post. Wish I had this years ago
2010 xc90 3.2 | 2008 xc 70 3.2
Have you tried the Torque app if it works with a Bluetooth OBDII adapter for the trans fluid temp? I saw the option is there in the app, but never used it since I use VIDA.Great write up!! All I can think of is make sure fluid is up to temperature before checking fluid level. A simple OBD II reader will give you transmission fluid temperature which Volvo specifies between 50 and 60 degrees C
Torque has trans temp but it's passive (or whatever you'd call it), so for my P2 S60 and P3 XC60, it's always exactly the same as the coolant temp, which is not accurate for true trans tempsDon't believe the Torque app has temp for transmission oil.
That's breaking rule 101... you're changing the properties of the fluid.I have red a few posts where people are using an additive like "seafoam, lucas, or Lube guard" what about these "cleaners conditioners?
+1That's breaking rule 101... you're changing the properties of the fluid.
Well, since this is a fluid thread, I know that neither Ford nor Volvo manufacture their own transmission fluid.I'd genuinely be interested to know what Ford engineering went into the XC90? The platform pre-dates Ford ownership, suspension and steering are model specific and are modified from the P2 platform, the engines (aside from the V8) are in house Volvo units, transmissions are of far eastern origin...that doesn't seem to leave much else.
I know a lot of cribbing went the other way - Volvo engines to Ford, sat nav and ignition keys to Aston Martin, etc - but can see very little, if any, Ford in the XC90.
Great list of handy tips though.
Could you take a screen shot of VIDA showing the fluid. This would be helpful for others who fall in the transition period.Are we sure about that chassis number?
My 2011 is 596394, and I was confident enough from forum research and VIDA that T-IV has been the right stuff.
-Ryan
The last 6 digits of the VIN.How do I know what my chassis number is so I can determine the correct fluid part number?
Last 6: 459815The last 6 digits of the VIN.
It's Rule 101Rule 101: Use specific spec'd fluid. JWS 3309 or T-IV for earlier version (Last 6 digits of chassis # before 568001). Fluids proven to do well are factory Volvo (p/n 1161640), Mobil 3309, Aisin T-IV, Idemitsu TLS (JWS 3309), Toyota T-IV, Ravenol T-IV. All V8s use the JWS3309/T-IV spec.
