SPA XC90 DIY Oil Change with pics, UOA
I did an oil change on our 2018 XC90 at 5k miles, these steps and pics should apply for any 2016/2017/2018/2019 vehicle.
[This thread is for those interested in doing the oil change, not intended to start a holy war. Head over to BITOG for that
See Post 36 for UOA! (Used Oil Analysis)
Materials:
Filter
(Comes with new crush washer, two rubber o-rings for filter housing and one o-ring on filter itself)
Amazon.com: Genuine Volvo 31372212, Engine Oil Filter (Includes Drain Plug Gasket 977751) : Automotive
Wrench
Amazon.com: Motivx Tools MX2322-US 86.4mm 16 Flute Precision CNC Machined Aluminum Oil Filter Wrench Compatible with 2014 and Newer Volvo 2.0L 4 Cylinder Turbo Engines : Automotive
Oil (Available from Walmart at a very good price and occasionally goes on sale at Amazon)
Amazon.com: Pennzoil Platinum Full Synthetic 5W-30 Motor Oil (1-Quart, Single) : Automotive
Tools:
Volvo Oil Recommendation:
EDIT July 25, 2025: The Volvo recommendation below is included only for historical reasons! Please read the owners manual for your vehicle and act accordingly.
(Also read this entire thread, the oil viscosity and grade are discussed. Or read bobistheoilguy.com, or google...)
NOTE: Volvo now specifies 0W-20 for their SPA vehicles regardless of what is shown in the owner's manual. Oil must meet Volvo spec RBS0-2AE.
Steps:
Service light reset:
Volvo oil filter wrench
Removing T30 screw, holding the skid plate
Drain bolt location, middle of pic
Removing oil drain bolt
Oil draining
(I recycled it, no whales or dolphins died...)
The oil filter housing
Removing the bolt from oil filter housing, T40 Torx or 6mm Allen will work
Removing the oil filter housing
Old oil filter within housing
Oil filter
Oil filter components
T40 Torx driver, supposedly it's actually a 6mm Allen bolt
Filter bottom bolt and o-ring
Location of large o-ring on filter housing
New filter installed in housing
Drain bolt with new crush washer installed
Installing filter housing
All done!
Materials:
Filter
Wrench
Tools:
- 17mm hex wrench
- T30 Torx driver (T27 also fits)
- T40 Torx driver or 6mm Allen
Steps:
- Loosen oil cap under the hood
- Remove the skid plate (10 T30 Torx screws, plus two spring loaded inserts; T27 also fits)
- Remove the oil drain plug (17mm hex bolt)
- Drain oil into suitable container
- Replace the drain bolt with new crush washer, tighten slightly past 'snug'
- Optionally remove the T40/6mm bolt from bottom of filter housing (to drain initial oil in filter) [Either T40 Torx or 6mm Allen wrench will fit]
- Remove the filter housing with the Volvo oil wrench
- Replace the filter within the housing
- Replace the large o-ring on the housing
- Replace the small o-ring on the T40/Allen bolt (bottom of filter housing) [If you removed the bolt]
- Apply oil to all o-rings!
- Replace the T40/6mm bolt [if you removed it]
- Screw in the filter & housing back into engine, I had to use the wrench again. Do not tighten very much! Let the o-ring do the work.
- Replace skid plate
- Fill engine with 6.2qt of specified oil [Note: 2016-2017 is 6.2qt; 2018 and newer are 5.9 qt]
Oil draining
Oil filter
All done!
