Hi all-
About an hour into a road trip, the ac (set to coldest on both sides) with fan quite high, fresh air set to auto, basically stopped blowing cold, and the air coming out of the vents really slowed down along with a high amount of noise coming from the blower fan area. I turned the ac off and over the course of about 5-10 min, the air coming out of the vents increased back to normal.
After another 10 min, I flipped the ac on- works great. In the meantime, I’m setting the temp to something comfortable, but not full cold, and I turned the air circulator to manually on.
anyone have words of wisdom?
Edit 7/24:
I finally got around to digging into this. After reading up on the issue some more, I decided to try replacing the likely aging ac control valve rather than replacing the compressor. I bought a cheap ish one on Amazon, and had a shop evac the Freon. Surprisingly, the shop said the levels were at 1.5 pounds (non-dual ac) rather than the 2.2 lbs listed for xc90’s with dual ac as mine does.
So I replaced the valve (fairly easy to do- take the extra 5 minutes to remove the air box- makes the job a lot easier) put 2.2 lbs in and the ac works much better than it did before- especially at idle. Going on a road trip on Friday so we’ll see how that one goes.
Edit 7/24:
