Does anyone know how to keep awd turned on the 2004 volvo s60r with m66 manual transmission
What i mean is to keep awd on when not losing traction. I have heard some people that have done something to their awd to make it be activated when not losing traction. Sorry should have clarified more.If the AWD system works then it is always "on". If your AWD is not working then you have other issues and would need to diagnose what's causing the AWD not to work. It can be a number of things that can cause the AWD to not work. Your car has poor AWD system where the AWD typically fails.
It can go from 100/0 to 0/100.If I'm correct it's always a 90/10 split and up to 60/40.
Is there not a solenoid that maintains the hydraulic pressure to keep the clutches engaged after the pump generates the initial pressure from the difference in rotational speed?With gen 2 haldex, which is what's in the 04 Rs, I don't think this is possible without some compromises.
The haldex has a clutchpack that transfers power from the haldex input (driveshaft from angle gear which is always powered) to the output (rear differential then to rear wheels.) The clutchpack is engaged by hydraulic force. The hydraulic force in the gen 2 haldex is generated by a mechanical pump that runs when there is a difference in rotational speed from the haldex input shaft to the output shaft. I don't think sustained clutchpack lock can be easily achieved in this system. If the input shaft and output shaft are spinning at the same speed (locked clutch) then the mechanical pump is not being driven and no more hydraulic clamping force can be generated. The clutch can't be locked from a dig either, requires front wheels to be moving.
