Installation: Used a hammer, screw driver and chisel to wedge the plastic framed bushings out. Yeah it was a pain in the butt and took about 10-15 min per bushing. This is with me on the ground, car on jack stands. For some reason I thought that the new delrin bushings would just plop right in there and the weight of the jack pressing up on them would seat them in easily. Not the case. In order to get these puppies seated correctly I had to cut two "spacers" from 3.5" aluminum tubing I had laying around to put between the subframe and the frame, then draw the delrein bushing in with the subframe bolt and impact gun. Two different spacers were needed because the bolts aren't long enough to reach the frame with the tall spacer in AND the delrin bushing all the way unseated. So you draw them in with the smaller spacer, back the bolt back out, put in the taller spacer and draw the bushing in the rest of the way.
Here's a crude rendering:
Conclusion: Ridiculously stiff and that's exactly what I expected. You don't know how much those rubber bushings move until you replace them with the almost solid delrin.
Updated conclusion so none of this between the quotes is correct any more//////"It's a gritty connection to the engine, you can FEEL the engine through the steering wheel and footboard. The WORST side-effect is the drone/vibration at idle while in gear. The dash (up toward the windshield) actually shakes and the wing on the roof rattles pretty loudly. I think it's the wires inside for the brake light that are flapping around at just the right frequency to BUZZ. If I put it in neutral the vibration goes away. This wouldn't be an issue for the manual guys since when you're stopped with the clutch in there's the engine isn't torque-ing against the motor mounts."//////
The vibration at idle was caused by the poly lower trans mount I added at the same time as the delrin subframe bushings. Just threw a stock one on and ALL the vibrations at idle while in Drive are gone!
Anyway, all in all, happy I did it. It actually LESSENED my 70mph vibration by quite a bit, which is undoubtedly a funky axle.
