Hi everyone,
Does anyone have any advice, tips or tricks for removing stuck ball joints when not working on a lift?
My vehicle has 0 corrosion, we don't get snow, they don't salt the roads, we only get constant rain.
Original ball joints, original LCAs, 162k km.
The ball joints are not worn, doing them as preventative maintenance while doing the LCAs.
I've been following tutorials (linked below) with no avail using the following approaches:
My ideas for next steps:
I have two new Lemforder ball joints ready to go in.
View my apprentice marks below and think positive thoughts for my CV axle (at one point that pulled out too much for comfort but appear to be fine):
Thank you in advance for your help
- Sea Foam Deep Creep overnight
- air hammer
- punch
- blunt cold chisel
- screwdriver on ears of ball joint
- Take the entire steering knuckle off the car and:
- Put it in a vice and slide hammer it out.
- Take off everything temperature sensitive and heat it, and then air hammer it on the ground
- Cut it off with a grinder and dremel while on the car
