Hey all,
I have unfortunately found myself in (edit:// possible) need of tearing down the wife's XC90 to do a head gasket.
So, I am looking at parts and I have a few questions before I get started.
I am going to remove the head and have a local machine shop magnaflux and check the head out. I'll probably have them do the valve stem seals while they're in there.
Assuming that all is well there, I know that I will need a head gasket set for starters.
I'd like to do what needs to be done while I'm in there (like the alternator seal, drive belt for a/c, etc).
The problem is that I don't actually know what else needs to be done.
Seems like I should do the chain and tensioner - the water pump too.
Please let me know what you all suggest (especially if you have already done this job).
It's already getting kinda $$$$. I don't want to leave anything out - or go too far with it.
Thanks in advance.
Thanks in advance.
