Are there any options to replace this trash?
Looked into this myself and as far as I can tell, no. There's only overpriced no warranty Chinese junk that works with some car features but not others.Are there any options to replace this trash?
Are you using the teyes adapter or the InfoAdapter you referenced above?
Thanks @someluo ! Definitely appreciate the feedback, as well as the detailed pictures ! Those are always great for referenceHi I am from China with a 2016 XC60 B5204T9 5cy,
Last month I add a wireless Carplay Box to it by myself, I think it is very good for a old style volvo.
The good stuffs are:
The only things that are not perfect:
- Non-destructive installation,just plug in the cable connector and hide the carplay box to copilot side
- The orignal LCD has adjustable brightness and display quality is good and its resolution is also enough for Carplay
- Well embedded into the original system, can be controlled by steering wheel buttons. switch bettween them smoothly by exit key or other function keys
- wireless connected everytime you get into the car
- Carplay itself brings high quality music and navigation apps that a driver really need
I really enjoy it, and use Siri to navigate or play music every time. It seems the phone battery also drops very slowly in Carply mode since screen is off.
- Powered by the ACC Power, so works weired when only electricity is on(engine off)
- Seat heating and volume indicator not appeared on the carplay screen
I notice you are on Aux up top on the display is that. Is that how the Teyes radio works? Did you move the Fibers on the back plug to the Teyes plug?I would suggets to keep the original.
I bought an android on AliExpress for my volvo and some of the features didnt work , like steering wheel commands,car Audio (it needed to be connected to the AUX IN).
Anyway it was well designed.
Mam zestaw TEYES, który jest wyposażony w (podczas zmiany konsoli z podstawowymi aluminium na nowoczesne/liniowe drewno) i ten sam zestaw, co @bs-volvo. Podłącza się do źródła sygnału i sygnału dźwiękowego przez kanał AUX.
Można zastosować, na które należy zwrócić uwagę, są zestawy „infodapter” Connects2. AFAICT, podstawowego podstawowego zestawu „OD-VOLVO-01”, który przekazuje informacje o klimacie do radioodtwarzacza z systemu Android za dedykowanego połączenia szeregowego, Connects2 interpretuje więcej tych urządzeń CAN w sygnale wideo, który jest podawany do radioodtwarzacza dostępnego na rynku wtórnym przez kanał kamery cofania
Connects2 — integracja z pojazdem (pełny zestaw z wyposażeniem DIN)
Connects2 – Integracja pojazdu (to samo, bez deski rozdzielczej)
Instrukcja obsługi obejmująca więcej funkcji na temat interfejsu „infodaptera” — obsługa naśladują podstawowy interfejs Volvo, który jest widoczny na zewnętrznym ekranie, w postaci aplikacji do urządzeń radiowych cofania nowej radioodtwarzacza
[ZAŁĄCZ=pełny]181470[/ZAŁĄCZ]
Interesujące jest również okablowanie instalacyjne — nadal konieczne jest użycie piny w „złączu wzmacniacza”, aby uzyskać dostęp, w jaki sposób sygnał audio jest przekazywany do systemu audio (z obejściem czy nie wzmacniaczem, zestaw podstawowy ma WIĘCEJ wejściowy, więc na pewno nie przez WIĘKSZOŚĆ ).
[ZAŁĄCZ=pełny]181469[/ZAŁĄCZ]
Ze schematu instalacji AFAICT wynika, że „moduł interfejsu” przejmuje kontrolę nad wzmacniaczem i wysyła sygnał audio z „złącza ISO” do modułu interfejsu, który faktycznie włącza zasilanie. Martwiłbym się również, że CEM nie będzie korzyści z odłączenia AUD i IAM, ale kto wie.
W każdym przypadku, chiński zestaw nie jest dobry, dostępny dodam Connects2 CTUVL02, aby uzyskać infodapter i dokładny kontroler dźwięku. W przypadku, który mógłby wystąpić, oprogramowanie do zastosowania rozwiązania CAN i jest dostępne do radioodtwarzacza poprzez chiński szeregowy, który jest wyposażony w urządzenia te, ale wolałbym nie iść aż tak daleko 🙃
