Hi gang. I hope you don't mind my bouncing this off of you- I'm a little shell shocked. It's an '05 S40 T5 w/ 75K on it, passed inspection at a very reputable Volvo indie shop in March, not lowered in any way- all stock. Last alignment was done about 5K ago and it's all out of whack again (which isn't unlikely, given the shape of the roads around here.) I took it this morning to a local shop that specializes in alignment, since the last shop was a tire place that doesn't necessarily specialize in this, and also given the fact that the last alignment didn't hold up.
Anyway, the shop called to say my 80.00 four wheel alignment would be 1,200. They said that the rear is at it's outer limits of adjustability and therefore it requires the camber kit. Also the front control arms need replacing. I've attached the estimate and specs on the alignment below.
Now I know that rear camber is an issue w/ these cars and if you want to 'fix it for life' then the camber kit is necessary (otherwise you'll always be wearing the inside edges.) Still, I have a hard time believing that a car w/ 75K on it cannot have the rear adjusted a bit more. There's no way I'll spend 1200 on this- no offense to anyone here (as I do understand the S40 love) but this car just isn't worth that much to me...I've never bonded with it, so to speak. I do have an appt. w/ the indie Volvo shop for Monday, so will keep you posted. In the meantime I thought I'd get your thoughts as a.) I trust this place and you guys have always been a great source of advice and b.) I wish to be armed with knowledge when I talk to both of these shops. Let me try to post some pics of the docs they gave me:
Thanks!!!
Thanks!!!
