101 - 120 of 288 Posts
Discussion starter · #101 ·
Ryan,
Pretty accurate evaluation of the Short Inline 6. I've become somewhat of a go to guy for everything related to the READ unit. I have a site with a lot of valuable information on the READ units, so I thought I would share it here.
Thanks
Scott
Thanks, Scott!
You are a bit of a legend in my mind ever since I found your original video on YouTube. I followed that trail of bread crumbs to your shop, and I believe downloaded the READ tech journal from your site as well. Fascinating stuff. I've not had READ problems, but really enjoyed reading/watching your information as you present it very well.
Thanks very much for adding to this thread! Can't wait to check out the new info on your page!
-Ryan
I do agree that the B6342S engine has some downsides to it but at the same time, the thing just keeps going. I am one of the lucky ones where I don't have oil consumption issues..... but somehow oil baffle consumption issues? The other day I notices when looking in everything since I got nothing better to do.... and I noticed when I looked down the oil cap there were oil baffles and I'm pretty sure that there isn't supposed to be a chunk of it missing. But somehow the thing is still chugging on. I do want to check the internals to see what has happened but at the same time it isn't broken so why fix it. I was wondering if anyone else has had this problem before and what has happened?
I decided to change out my coils with 152k miles on the odometer. Personally, I cannot be caught in one of my 11 hr cross-country drives with a bad coil in the middle of the night. So, here is some preventative maintenance. I put 3 of the old ones in a box next to the battery just in case.
I am very happy I did. Anyone with a 2.5t knows how new plugs and coils can bring back the life of the engine at 100k miles. While the 3.2 is not forced induction, it does benefit from fresh coils. With the new coils at my 152k miles, the XC90 feels 200lbs lighter. I don't have to go as far down on the accelerator pedal in my normal drives and the overall fuel mileage is better. Check this maintenance item to do around 150k miles or earlier. I now see the benefit of not waiting for a coil to fail in this engine. The improved MPG should offset the cost in two years and those two years are with a better & healthier running engine.
The Delphi coils are the exact same coils that came on the engine. I have pics below. The box says Delphi, the part says Denso and FoMoCo (Ford). Part numbers are exactly the same.
Wanted to share an unfortunate experience with AC Delco ignition coils on a 3.2. It can cost much more in damages and fixes if you get cheaper parts: What did you do with your XC90 today? Scroll to read more of the conversation.
This is a thread of cheap coils on a V8 that went bad: Cheap chinese coil packs off of amazon.- a tradegedy in...
This is to say, get good known quality coils as good prevention and assurance. I bought mine at FCP and they have a lifetime warranty.
Discussion starter · #104 ·
We have two 3.2L's in the driveway. So, I bought a single coil pack from Volvo to have as a spare. I'll have too look, but all my 3.2L coils are Denso, IIRC.
-Ryan
I've been having intermittent shuddering at idle. It feels almost like a misfire. But no codes. I pulled a plug to check and it looks a little toasty, and the gap measured 0.49. Not terrible, but not correct. I pulled another plug and that measured over 0.55. I'm guessing these were not changed at the 70k service.
Any reason not to run the OE Denso Iridium TT 4704? I know in the subaru engines NGKs seemed to do a lot better.
Also, looking at the coil packs, they look pretty good. When I pulled the ones on my Honda at 120k they were discolored and the rubber was brittle. These seem almost new to me. Should I still replace them?
Well I'll answer my own questions. Denso 4704 are significantly better than what was in there, and only $9 each. Of the plugs pulled, gaps were between 0.045 and 0.06. One had a bad seal and there was a lot of burnt oil on the coil and the insulator. One had a broken insulator at the tip.
The car really struggled to run on the new plugs, for a bit. I'm guessing the ECU had been compensating heavily for the bad plugs. I'm ordering new coils because I bet these had been working pretty hard. Also going to do the PCV as it looks like there is some glue on it. Not sure if that was to fix a crack or not.
Just a word of warning, Delphi coils are no longer reboxed Denso/FoMoCo. I would guess the change was made when BorgWarner bought Delphi at the end of last year. My new coils have the same Delphi part number but are made in China (instead of Japan like the Denso). All of the photos of the Delphi coils show the FoMoCo stamp on the side. So the change must have been recent. I ordered mine from Rock Auto. I'm going to ask FCP if they noticed the change too.
I'm curious if this will affect the Volvo branded coils in the future or if they will somehow remain Denso made.
Good work. Please report back to what FCP says. I purchased mine from FCP and it would be great to get the most up to date information as well as what FCP's response is if there is a changeover of Volvo/Ford suppliers. Looking forward to hearing if the change is consistent with the Volvo boxed coils too.
Still good to know FCP has a lifetime warranty, even on Volvo parts bought through them.
When I looked into it, the options were limited. An aftermarket ecu advertised gains of a whopping 15%. An OBD2 tuner advertised "dyno proven 7hp and 22 ft-lbs torque gain", for $1k.
Hardly worth the effort. NA engines will never have the same gains as turbo engines. Most turbo engines are relatively tame from the factory prioritizing smoothness and reliability. So a tune is just sacrificing some of that "safety" for performance.
Discussion starter · #112 ·
Wow. 7hp is like a 3% increase. You probably get that simply by running premium and letting the engine management advance the timing. :)
Indeed, NA's are pretty much maxed out nowadays. More "power" typically comes from making things more efficient, and that's already the goal the manufacturers strive for. IPD just released a bunch of tunes for the 3.0L turbos. If there was any sense in doing so for the 3.2L, they probably would have done so.
-Ryan
On second thought, the LR2 already has the S5 variant which has 5 more HP than the XC90 version. I doubt there would be any gains on an LR2. But if you have $1k to splurge on a suspected 2hp then you have enough time and money to google it yourself. You're probably better off finding a performance shop who can do a custom turbo install. Or just buy a different car.
Sheesh, I have researched, I'm adding a more aggressive camshaft and need a tune.
The price of Delphi Ignition Coil at Rock Auto is attractive; any performance issues?
I figure we could get a 3.2L thread going. I'll kick it off, but hope others can add to it. I've only had my 2011 for a year now, but I've read as much as I could in VIDA and elsewhere. A great debt of thanks goes to Swedespeed forum members who have helped me out over the past year.
If you've ever worked on the twin-turbo T6 engine in the XC90, and wanted something more practical that was easier to work on, the B6324S is the engine for you. It, combined with the 3.0L turbo, comprises Volvo's "Short Inline 6" (SI6) Engines. Supposedly, the block is a smidgen shorter than the 5-cyl. Supposedly. These are designed by Volvo and built by Ford's factory in Whales. It is also used in the Land Rover Freestyle/LR2. Everything on it is easy access, especially under the hood of the XC90. Coming from Volvos older tried and true "Red Blocks", I actually really love this engine. The first iteration of the B6324S had some design issues that were remedied for the 2011 model year's B6324S5 engine. This later version of the engine uses a bit less motor oil, has fewer special tool requirements, and was "optimized" to be a little more efficient.
The normally aspirated 3.2L engine is perfectly "adequate". It's no sports car. I've driven the 3.0L turbo version in an XC60, and that does go like a stabbed rat. That said, the drive train connected to the 3.2L is the same used with the V8 of the same model year, so this engine is well within the drivetrain's limits. I've yet to hear of transmission or bevel gear failures. Yet.
It's worth pointing out that the SI6 engines use a different filter cartridge than the previous generation of engines.
The good (relative to earlier XC90 inline petrol engines):
-"Life time" timing chain
-All the stuff that was difficult to do on the old series of engines (PCV?) is dead simple on the SI6 engines. Some stuff is even easier to do than on my old RWD Volvo's.
-A camshaft driven vacuum pump runs the brake booster instead of an electric pump.
-Oil filter is a cinch to access.
-All of the engine accessories are easy access as they are run off of the Rear Engine Accessory Drive (READ)
The bad:
150K mile service is a little ouchy: It involves changing the serpentine belt and all that it touches. INA makes a number of the parts, and they can be had relatively inexpensively from FCP Euro. it does require some special tools to remove the decoupler pulley. These tools can be found as generic decoupler pulley tools. I have these written down somewhere. I'm hoping to do a video/write-up on mine in the next few weeks. While at it, do the thermostat housing at the 150K mile service. This service is probably a budget breaker if you do not DIY.
A set of special tools is needed to manipulate the cams and crankshaft should pretty much any engine work be needed. This set of tools is available aftermarket on eBay for $250-ish.
The intake manifold is plastic. There are a number of seals both for the manifold-head junction, as well as for the actuators that modulate the runner lengths. The seals for the latter are NLA from Volvo, but can be had from Land Rover. I'll share these numbers ASAP.
The ugly:
Volvo put the two of the four cat converters in the exhaust manifold. Currently, they are wallet cripplingly expensive.
READ units prior to late 2010 model year have failure issues. The system is splash lubricated, and the bearings can be failure areas. Rebuilds are possible, but expensive (A machine ship really needs to do this work), and special tools are needed to get the READ unit out. Used units are available, and have been used, though VIDA claims that each READ unit is machined to be specific to each engine block. The newer "S5" engines (2011-on) have ball bearings instead of needle bearings in the READ unit. This bearing change seems to be a step in the right direction.
The A/C bracket on earlier B6324S engines needed special tools to realign if removed. This, too, was changed for the S5 version, and no special tools are needed.
There's definite hit or miss oil consumption with these engines. I've been fortunate with mine at 150K miles, though people with engines older and newer than mine have reported problems. I'm running 5W-30 Mobil 1.
Please feel free to correct me, and to add to what you know. There are some really excellent folks in this forum that have really helped me.
Thanks, all!
-Ryan
what do you think of using 10w or 20w oil in order to avoid oil burnt or consumption?
Been using Mobil 1 0W-40 for the past ~70-80k miles, with an oil change interval of around ~5,500 miles, and I have zero oil consumption. Please read earlier in this thread. Here is a specific post, but others have chimed in:
I actually haven't had a chance to swap them in yet. I'm probably going to do it with the next oil change which should be next weekend.
OK, I've replaced all 6 ignition coils with RockAuto's DELPHI GN10558 at 152,000 miles; so far no issues. it is under 3-year/36000 miles warranty.
What was the brand(s) stamped on the ignition coil?
