SPA V60 with 18” Focus ST rims
4.3K views 20 replies 8 participants last post by  MichaelCG
Does it fit? I have found threads talking about P3 V60, but not SPA. I know pattern, width, and hub bore are good to go….it’s the 55mm offset that concerns me. I can’t find Volvo rims local to me, but can find Focus and Fusion rims galore. Wanting a set for winter tires, but not much luck yet.
Try Tire Rack for availability. You can get wheel and tire packages that are already mounted and balanced shipped right to your door. Just bolt them on and you're good to go.
Focus ST wheels should fit, but you're probably gonna need spacers. Likely going to end up being cheaper to just find something on Tire Rack.
Well, doesn’t appear I am getting the answer I had hoped for.
I was after used rims for a reason, not wanting to spend $1000-1500 on rims then tires. As well as used means already scratched and dented to make hitting pot holes and destroying them over the winter months less painful. Cheap aftermarket rims usually are…well…cheap and don’t hold up well.
Guess I will just hold out for the miracle that someone local has a S60 or V60 and dumping their OE rims…but that is very unlikely where I live. I think S90 rims are similar spec, but those are even more rare around here. But also looks like the XC90, which is way more common has similar rim specs.
My experiences with a good aftermarket wheel has been very positive. I have bent wheels on Mercedes’, Audi and my XC70s. I have TSW and Fifteen52 currently and no issues…….but, I run a 40 and a 55 series tire on them. My Mercedes uses factory staggered wheels in 20”. I bent a front at 9k miles, it was repaired with wheel insurance. So, for me it’s all about pothole size and edges, aspect ratio and cast, flow forged or forged. I hit a huge pothole in my 2014 A8 at night at 75-80 mph. It hit SO hard I immediately pulled over……no damage at all, a TSW rotary forged wheel with a 40 aspect 20” tire. I had the car inspected a few days later for suspension damage the hit was so vicious…. No damage🤞
Reactions: V50_M66
#21 ·
CC offsets are different. I haven't confirmed if a spacer is needed, but by the time you buy proper spacers, the costs are not minimal. When I look at factory specs, the S/V60 is a +42, the CC is +50.5, and the ford rims are +55. When I asked about the Ford rims, everyone said I must have spacers.
The S90 wheels should be a +42.5 or +47 (depends if 8 or 8.5 wide) on a V90CC which should be a 50.5. So overall pretty darn close to spec. Nobody has been able to confirm with me on how far off up or down on the offset we can get away with before spacers are required.
