I suppose before ordering parts for a 55 year old, I should scrutinize the supplier more.
TL;DR: What has been your experience, if any, ordering parts from Classic Volvo Restoration?
I'm undertaking a needed refresh of the cooling on my '67 122s, B18D.
I purchased a set of the upper and lower coolant pipes from CVR. This was paired with the GMB waterpump that IPD offers. I chose to order the pipes from CVR rather than IPD to avoid the lead time on the lower or inlet pipe, and the increased cost of the IPD parts (one VP, one Volvo)
Well, I learned a lesson here:
Both pipes will not align with their holes. It was difficult to get a good picture of the lower, but in this pic, the pipe is square with the water pump, and inserted all the way.
Believe it or not, upper is close enough to maybe be persuaded, helped by having a shorter bolt, and a weaker flange for the bolt to pass through, however at the not worth the risk by a mile price of putting shear stress on hardware holding your cooling system together, and angling the pipe in the hole on the water pump to an egregious amount.
The old, probably original pipes are crusty, at the hose ends on both there is a less-than-ideal amount of metal lost to corrosion. They are serviceable, (certainly more than their replacements).
This is half rant half asking for insight: With no welder at your disposal, how would you build up the metal on a corroded hose-to-pipe sealing surface? Would properly cured JB Weld hold up to coolant, assuming no rust underneath?
Much love, going to go wire wheel and paint instead of assemble...
