AWD Propshaft/Driveshaft CV Repair
23K views 22 replies 12 participants last post by  lookforjoe
With my current Propshaft issues I've been trying to find step by step instructions for overhaul of the darn thing. After a couple of days searching I found the TNN for the repair and thought I would share since this is much nicer to follow than VIDA. If your are getting a bad vibration under your pants this may be the culprit. I haven't included the removal and install instructions this is simply the repair of the joint itself, Perhaps another member will chime in.
Enjoy:
Drivetrain - Front Driveshaft CV Joint Service
NO: 46-10
DATE: 4-27-2007
MODEL YEAR:
1998- AWD (All Wheel Drive) Cars
SUBJECT:
Propeller Shaft Front CV (constant velocity) Joint Available as a Spare Part
DESCRIPTION:
The front CV joint for original equipment propshafts on all AWD cars is now available as a
spare part kit. This kit includes the boot, joint W/seals, cover, clamp, lock-ring, seals and grease.
SERVICE:
If the joint has failed, replace it according to the instructions in VIDA. Be sure to mark the rear flange of the shaft in relation to the flange on the rear axle, to prevent a vibration. Note that on some variants, different length bolts may be used at the rear for balancing purposes, and they should be installed in the same position they were removed from. The entire shaft should only be replaced if the center bearing has failed or if the tube is physically damaged.
Note: When handling a propeller shaft out of the vehicle, it is important to support it so that the boot on the center joint is not damaged. Allowing the shaft to fold at the center joint may cause the boot to be cut by the edge of the joint.
Note: It is normal for the front & rear joints to feel stiff when the propeller shaft is out of the vehicle. (These are not the same type of joints as the ones used on front axles.)
Note: The joint is not symmetrical. It should be installed according to the pictures.
1. Pop off the front cover using a screwdriver.
2. Remove the snap ring.
3. Remove & discard the boot clamp (1).
4. Remove the joint from the shaft using puller 999 5427 or knock it off using a plastic mallet.
5. Clean the shaft and splines. Drop the new boot clamp onto the shaft.
6. Check that there is a gasket on each side of the joint & that they are properly positioned.
Squeeze the grease into the joint (2). There must not be any grease on the mating surface (1). Install the boot on the joint. Ensure that the holes are aligned.
7. Install the joint on the shaft. knock it into place using a rubber mallet. Use a socket as a spacer.
Install the snap ring. Check that it is in the groove.
8. Squeeze the remaining grease into the joint (2). The entire contents of the tube must be used.
9. Press the cover onto the joint, using 2 washers, 4 screws and 4 nuts. Tighten crosswise until the cover bottoms on the joint. Remove the screws, nuts and washers.
10. Press the air out of the boot. Ensure that the boot is positioned correctly on the shaft. Install the new clamp (1).
Personal note: I have not attached the labor codes as they are unreasonable time wise for any technician to complete repair. I do not want to make any tech's lives harder, especially the ones who are members on this site and provide assistance to the forum members free of charge.
What are the symptoms of a bad CV joint or half shaft assy? I just developed a bad clunking noise when the steering wheel is moved side to side while parked. With my hand on the drive shafts on both sides of the car, I can feel lateral play that goes with the clunking like it is internal to the trans.
Any ideas?
Any ideas?
This CV is front to rear driveshaft CV, not axle's to wheels FYI. However, I will say some Lateral axle shaft play is normal to allow movement during compression/decompression of suspension. Bad axle CV would show up as clicking noise usually when turning the wheel to max lock in either direction while driving. I would first check the CV boots for damage or leaking it's pretty rare IMO to have a bad axle CV without a loss a grease or contamination of the joint ON STOCK suspension, If you have lowered your car be prepared to have this be a common issue. I may be wrong, I would suggest searching for someone who may have same issue as yourself or starting a new thread to get more responses to your issue. Best of luck
Stickied was nice but all of the photobucket pics have disappeared. A
As I may be dealing with this soon, could the original poster re-upload the pics?
Thanks!
-MIJ
Reactions: jxramos
#17 ·
Has anyone done this? I find myself where i need to replace mine. i have terrible clunking when shifting gears and going over certain bumps and pot holes. After closer inspection, i can see my CV joint twist/turn when selecting gear, but the actual prop shaft doesnt move. That leads me to this.
How difficult is it to remove the prop shaft on the floor with regular jack and jack stands? do i need to drop exhaust to get it out?
Any tip and/or info is apreciated :)
#18 ·
Just a small bump up, but a quick question for the ones who have experience with this;
on my 2004 V70R I would like to preventative (no problems right now, would like to keep it that way at 240k km/170k miles) regrease both outer CV joints on the propshaft. Propshaft needs to be partially removed anyway as I will service haldex as well and the driveshaft is blocking removal of the haldex filter and pump. So 2 birds one stone I hope.
My question is, I bought Moly Lithium Lubricant, but if I remove the caps of both outer joints, do I need to have new seals ready, or do I reuse these? hard to see if these are some rubber re-usable pads, or I need to arrange new gaskets. In other words, are there any consumables I need to replace once the joint has been opened?
Once I have my drive shaft removed, I do not have a another car at my disposal, so would like to have all parts in advance.
Other side quesitons, I am not planning to remove the whole joint (only the caps), but what would be the best way to clean the joints out of old grease? I read preferably not brake cleaner, but would wd-40 do any harm?
As always, thanks!
#19 · (Edited)
As always, thanks!
Cv's need to be disassembled from the DS to clean for regreasing. No possible way to remove all the dried up, caked grease & do the job right if you don't dismantle & soak the components. Sure, you could shove fresh grease in the boot, it's not going to mean much. I put gasoline in a small bucket & sloosh the CV around to get the grease out, using a small hardbristle paint brush. Don't take the actual CV apart, unless you have clearly marked the orientation of the inner, cage, and outer hub.
#20 ·
Any recommendations on the driveshaft CV joint brand? I'm seeing a HUGE variation in prices - from less than $40 for aftermarket on Ebay to $330 for Volvo on FCP. It looks like it is available from ProParts Sweden, Febest, IPD amongst others. Obviously the OEM version would be best, but is it worth almost 10x as much?
#22 ·
I was looking at these... How do they compare with OEM in general fitment and dimensions?
When removing the drive shaft, my joint separated. The shaft and bearings came out, but the cup portion is rusted in place and I haven't been able to get it off.
No signs of wear or heat scoring, so I'm content with reusing the cup portion and simply rebuilding the CV joint around it. But I'm curious if any of these aftermarket options would mate up with the Volvo pieces, or if I need to cash out for OEM for a proper fitment.
