Hi All,
New to the forum. I'm in a bit of a pickle and would like some advice.
I purchased a pretty beat up 2008 XC90 3.2 AWD for a dirt cheap (more on why that matters later). 145K on the clock.
~$800 in diagnoses, a fuel pressure sensor and a new battery revealed the following:
1) Complete brake job (rotors, pads, shoes...$1700) pads are apparently 1-2mm all around
2) Both front control arms ($1700)
3) 150K service (belts, tensioners, water pump and alternator coupler...$2700)
4) 2-3 oil leaks (~$500)
4) Oil change, other fluid flushes etc....
5) Then the big one....a "rattle" in the engine (they apparently won't do teardowns to find out what is actually causing an "internal fault," so they're quoting 17K for a new engine, p&l)...talk about throwing out the baby with the bath water...🙃
So a couple of interesting things...
1) When I asked if the car is "shot" they said, if you do the brakes, then it just becomes a matter of if/when the engine blows due to whatever is rattling, but it would definitely be "drive-able" until such time
2) I've reviewed a few rattling noises on these engines (on this forum) and it appears to be the very same pulleys/water pump that they're preparing to replace anyway.
but that's the catch...I wouldn't know unless I drop another 2-3K in repairs
3) Given the used market right now, I can rationalize spending a bit on this as I would imagine these can run north of 230K miles (which should, as my secondary car, get me about 6-8 years...hence why I mentioned not having paid much for it).
I'm thinking even if I bought one from a dealership, I'll still probably have a few $K in repairs (after spending probably 3-800 getting a mechanic to do PPIs finding the once I want).
My "wrench skills" are probably at their peak with a brake change (not to mention, I'm not sure I want to get an electronic torque wrench as this would be the only time I'd use it in probably the next 5 years).
So that's my sob story. Again any advice is appreciated (mainly, how you might go about determining the best course of action, and what seems dire, vs optional)?
P.S....oh and indy's are saying they'll come in slightly cheaper...yay for me...I guess?
Thanks!
Thanks!
