Well, making a more determined effort to make speed sensitive steering work on my R. Last time I checked and replaced the fuse as indicated in manual, no love. Set it aside, now taking another try at it. Doug has posted a link to very substantial information here :
http://www.volvoclub.org.uk/tech/2004r/R5-Steering.pdf
SO questions are:
1. What needed to be fixed to make your speed sensitive steering work?
2. Where exactly on steering column is the item #7? DO I need to remove any panels/covers to get to it?
3. Is there an easy way to test out parts of the system?
Is it wrong to...
4. think the rack solenoid being heavy duty part is a less likely failure part?
5. Believe CEM would throw a code if failing?
6. Believe BCM or other part would throw code?
update: found this link perhaps this is the same BCM:
http://www.volvopartsconnect.com/pages/index.cfm?action=viewPage&siteid=215102&pageid=11017
I wonder if autozone scanner could pick up any codes from this system...
Nuff questions, any help appreciated..
C
SO questions are:
Is it wrong to...
C
