1 - 18 of 18 Posts
kevviek
My 2016 T6 Inscription has started losing it’s position on the sat nav, randomly jumping to a nearby street or suburb and trying to align its travel with streets that it is not on. Switching the car off and on doesn’t fix it, I have tried locking and walking away, but that doesn’t help either. Eventually it will come good.
Has anyone else had this issue, thoughts on cause? I had the maps update by the dealer last week and it happened again yesterday.
Are the date and time accurate and set to automatic?
Sent from my BE2028 using Tapatalk
I had the same issue twice. The first time it fixed itself after several on and off’s. The second time I took it in and the dealer just updated the maps, at a charge of course. They said the maps have to be updated or you run Into this issue. Sounds fishy and I have done my own updates via a usb from volvo we’d site for map updates. Try that first and if no luck, head for the dealer who may charge you.
Discussion starter · #5 ·
Thanks. The dealer updated the maps a few weeks back and it is still happening. That’s why I posted here…
Did you ever get this fixed? My 2016 just started doing the same and didn't fix itself after a USB maps update. I have an appointment with the dealer next week for a full system update at $230.00....
[edit]
After short research... it seems for newer Volvos than mine...
Yes, looks that battery was changed after 2016.
for 2016 battery part number 31350776
photos not from XC90, from older models with this battery
1 - 18 of 18 Posts
