So here's the deal: propshaft front CV joint took some damage after the bevel gear blew up and caused massive vibration. So out it came again, waiting for a replacement.
However, some vibration remained. Normally it's smooth and steady but after I accelerate hard it starts to vibrate again, but the curious part is that it goes away by itself after a couple of miles.
Passenger side front driveshaft is fresh, just 10k miles on it if that, wheel bearings are fine. So I'm starting to suspect that the CV joints of driver's side driveshaft may bind under heavy torque and get stuck somehow for a minute once they do. Another possibility may be related to brakes (discs are due for replacement soon), but they would probably cause constant vibration were they the culprit.
Worst case scenario would be a transmission problem.
Has this happened to anyone else? Similar symptoms? If fixed, what was it? I'm a bit lost here, I haven't experienced anything quite like this before with any car.
