Where is Fuel pressure regulator? Next to the pump
20K views 15 replies 8 participants last post by  glj100
Car kept bucking when a nail it so brought it to a mechanic, its throwing the p089 code and he checks the pressure on the pumps and they're fine so he says it must be something further down. Isnt the regulator right next to the pump
and would the pressure sensor make the car buck like mad and completely lose pressure. I don't think it would. I am ****ing clueless at this point.
Thanks
As far as I know the actual regulator is part of the pump.
The fuel pressure sensor is on the right side(looking at the engine from the front) of the fuel rail.
Has the mechanic checked the pressure at the rail?[/QUOT
He checked it at the filter but its easy to check it at the end of the rail right? Your saying its possible something could have made it through the filter and be stuck in the rail itself? and if its fine at the filter its
probably not the regulator correct?
Thank you
I'm not sure what you guys are talking about, sensor is on the fuel rail, pump is in the tank and the regulator is under the car near the fuel filter. Not sure how someone could measure the pressure near the tank unless they somehow tapped into the line. Easiest place to check is the nipple on the fuel rail or electronically with a scanner.
there is also a Schrader valve next to the fuel filter near the FPS.
Perhaps controller is the better term instead of regulator. There is no mechanical fuel regulation in the R, just a sensor, controller and pump in the tank. The controller regulates fuel pressure by changing the duty cycle of the power circuit to the pump.
Ok Guys I will give you the benefit of my $2000 fuel fix.
My car just died at the side of the road. I replaced the fuel pump, but it was the FPS. Everything was fine for a week then I had hesitation, went through 2 fuel pumps and a pressure sensor. In the end it was a bad fill from a gas station and the filter on the fuel pumps was being blocked. I drained the fuel tank as much as possible but had to remove the screen on the fuel pump to get the car working again. 2 fill later and all is going fine.
There are 2 fuel pumps, 1 pumps fuel to the driver side of the tank to balance the fuel in the tank.
Check the screen on the fuel pump, it sounds that its blocked, what happens is that it will run at low rpm but when you want to accelerate the fuel pump is at maximum output and you lose pressure and the wiplash starts
