Re: wheel weigh for volvo 17 wheels? (V50_T5)
Hey, looks I can finally help V50_T5 after all the help you have given me. I have gone through this exact thought process, recently. I'm still considering the 17x7.5 R5 from Evolve. It looks good, is light (18 pounds), is probably very strong, and will not have any rubbing issues (42 mm offset).
But I'm more recently inclined to Volvo wheels also, all coming from S60. They are 49 mm offset, 17x7.5 wheels, and will fit except they need hubcentric rings. The Pegasus is 46 mm offset, 17x8. MOST LIKELY I WILL GO WITH PEGASUS.
Check out
http://forums.swedespeed.com/zerothread?id=53357
for info on weights of such wheels. Generally, the 17x7.5 are 22 pounds and 49 mm offset. The Sculptor 17x7 is 52.5 mm offset, also 22 pounds. The Pegasus is 25 pounds, 46 mm offset. Thanks for UKMatt for the info.
Not to bias you, but just to inform everyone of another guy's opinion, I've thought a lot about which wheel. In the end, they are all good options, all with different advantages, including the Evolve R5, which arguably looks the best. I'm probably gonna try the Pegasus wheel.
Here are some advatanges, disadvantages of the Volvo wheels
Sculptor:
pro: stock wheel, looks good, 52.5 mm perfect fit. For this, one might use 205/50/17 high quality sport tires and use the normal V50 wheel.
con: Using 225/45/17 on 7 inch wide is vastly inferior to 225/45/17 on 7.5 or 8 inch. Using 205/50/17 sport tire may give the biggest bang for the buck, but arguably not quite as good as 225/45/17 on wider wheel.
17x7.5 49 mm offset S60 wheels:
pro: close to 52.5 mm offset. Good weight - match Sculptor - fancy designs and many choices if you like any of them. Is the industry standard measurement rim for 225/45/17.
con: not 8 inches wide, none look as good as Pegasus (my personal opinion), need hubcentric ring, seemingly more expensive by a lot than Pegasus
17x8 46 mm Pegasus:
pro: 17x8 is even better than 17x7.5 for 225/45/17 for sidewall straightness and stiffness, arguably super-strong (designed for R), looks sporty and classy and not flashy (my personal taste)
con: 46 mm offset is a bit more of am offset / scrub radius change - effect still not quantifyable. 3 pounds heavier than 17x7.5 wheels, need hubcentric ring
By the way, 8 inches wide makes the 225 tire a few mm wider than 7.5 inches wide. But 46 mm makes up for the extra section width. So the 46 mm Pegasus with 225/45/17 will be about the same tire width as 225/45/17 with 17x7.5 S60 wheel. Both will grow less than 5 mm towards the inner car, from my own calculation.
Another aside concerning section width:
http://www.tirerack.com is great. You might think that 225 is 20 mm more than 205. Not so! A sport tire has narrower section width because it has straighter, stiffer sidewalls. So going from 205/50/17 all-season grand touring to 225/45/17 max summer performance only adds 10 mm or so, believe it or not, looking at the maximum section width.
Hope this helps!
