The dealer say 87 is fine... Do you find the engine runs smoother, quicker, or more fuel efficiently at 89 or 91?
Actually flip to the page in the owners manual, it says that for best results in performance of the motor use 91 or higher octane.I only use 87 on my T5. Runs smooth, no issues with power or MPG. Using premium in a car that does not require it is a waste of money IMHO.
Uh, no... The motor was designed to operate in a range. A computer learns and adjusts to run on whatever is available. Older simpler computers would still allow some detonation at WOT, when fuel is crappy and the day is hot. This one is probably better. It will absolutely run fine, and the difference is probably not that significant. I mean, whoever needs 350 torque anyway? ;-)The motor was designed for 87 and runs fine.
There are a number of factors that could influence this, but a local guy here that has a family member running 87 octane in their T6 measured peak boost at only like 8 or 9 psi. Run 91+ and you'll hit the advertised 13.1 PSI of boost. That is probably more like a 30+ HP difference if not more. After all, Polestar only goes up to 14.7 PSI of boost from 13.1 PSI but that got them +25 HP.I run 87 all the time, mpg is decent and power is OK.
It is very noticeable if I put 91+ in the tank. Must be at least 10 hp improvement and better throttle response. But mpg is the same.
Top Tier gas is more about the detergents and additives than octane.I've actually wondered why Sunoco isn't on the top tier list given they are the only ones I know of selling 100 octane around here (here it's not from the pump, though).
I wish there was actually more data than just GM's top tier BS, but from what I've been told being on that list can matter just as much as octane when it comes to performance. I didn't think these cars were tuned for more than 93.
The detergents help performance over thousands of miles because they keep the engine clean. But if you have a clean engine and you compare Top Tier 93 vs some other 93 with fewer detergents, that tankful will perform the same. The detergents aren't added in any quantity significant enough to change the chemical energy or octane properties of the fuel...Detergents and additives absolutely affect performance. Anything you put in a fuel will effect how well it performs.
I call BS. Unless you can show us a datalog from your car using VIDA/DICE or Torque app and an OBDII dongle or similar, there is no way I will believe you're getting anywhere near the advertised 15 PSI of boost that the T6 Polestar runs.I'm telling you, I have switched back and forth a zillion times between 87 and 91, and there is no change. No change in fuel economy, no change in throttle responsiveness, no change in acceleration, no change in smoothness.
