That sucks. I wonder if the Atlantis are designed thicker, with smaller inner diameter to better support SUV's. They also seem to have different hub bore and are also narrower, 17x7 so I guess an offset of 49mm would mean more, would need different spacers than the same offset on a 17x7.5" rim.
I'm thankful to Bruce for confirming the Thor worked for him with pretty much the same setup I have, coming from 18" Pegasus to the same 17" Thor rim, I have confidence it will work for me.
But totally agree, inner rim diameter is crucial with these Brembo calipers on the R's. Bolt pattern, rim outer diameter and hub diameter is not enough proof a rim will work.
Also spacers sizes need to be calculated for each rim type.
Sent from my SM-N950W using Tapatalk
