Howdy all,
2004 S60 AWD 2.5T with 163k on the clock.
Over the past month the car has developed some substantial vibrations/shaking when driving on the highway. I don't really notice them under 50 mph but become very noticeable in the 65-85mph range.
The vibrations feel like they come through the cabin and chassis itself and also noticeable in the steering wheel. I've had wheels that weren't balanced before but it didn't feel like this. The vibrations can be more or less severe at times...probably due to road conditions? Front struts, ball joints, and control arm bushings were recently replaced so they aren't the issue.
I had a mechanic look at it and they said the mounts looked a bit worn but not broken, but would worn be enough to do it?
Note: I replaced the Upper Engine Stabilizer Mount with the IPD Poly a few weeks ago (Polyurethane Upper Engine Stabilizer Mount for Volvo - IPD - 8649597 - 111086) because the original mount was completely broken in half. But the new Poly mount made matters worse, and the situation has only deteriorated since then.
Thoughts? Is there something I can check myself? Thank you!
