I've been having issues with my coolant system and I'm not sure if my problem is normal operation. I have recently replaced my hoses (ipd silicone), thermostat housing (OEM), coolant reservoir, and cap (both OEM volvo parts). I also flushed the system using distilled water and refilled with volvo OEM coolant. After driving the car for 4 hours to Phoenix, I decided to check the levels. To my dismay, the coolant in the reservoir was well below the min line. Luckily I had some spare coolant in the trunk in case this happened. When I went to take the cap off, there was a hissing sound (like the release of a vacuum, and then coolant from the return lines filled the tank and it was at the proper levels. My question is, is that normal operation? Are the min and max line only valid when the cap is off? I've let the car sit over night and cool off and it holds vacuum until I release the cap. What could be wrong here?
