V70R 4C Suspension or Bilstien
1 reading
25K views 36 replies 21 participants last post by  EricTheRed
Hi,
I Purchased a 2004 V70R back in January with 114k miles, now at 119k and am ready to improve the suspension.
I have been doing a lot of reading here regarding the 4C suspension and want to replace a number of components on the suspension to improve what I feel is loud crashing over pavement imperfections. I sometimes feel jiggling in the car as well as if the left front strut is worn out - though not always.
I have identified that I can switch to Bilstien HD or Sport struts and shocks with a few modifications: 4C resistor mod, move the accelerameters to the chassis, and weld on a flange for the rear shocks (convert them to a "coil over" style). Total cost for this and all the extra bushings is $1540...or... I can keep the 4C system for $1940.
Can the 4C system be made, though new bushings and springs and software updates, to perform very well?... or should i save the $400 and get a better system with Bilstiens?
I know, I loose the adjustable of the 4C, but I will never use the Advanced mode so taht is out, I do like the option of comfort for the interstate and sport for the rest of the time, but my past two cars (G8 GT and 335d) I was quite satisfied with their handling and ride with only one mode and I think Bilstien is a very good strut/shock.
Opinions?
It's probably not a direct answer to your question but I would never wanted to loose 4C functionality. I switch between modes all the time based on road conditions and my mood. I'm surprised to hear you use Comfort on highway, I usually 50/50 between sport/advance driving on highways. Well I use Comfort too but very rare, when I'm not alone.
My V has about 95k on it now and I'm planning to refresh most of suspension components including all 4 struts. One is busted for sure. Not sure about the rest.. BTW I had Bilstein in my S70 and it was OK, probably close to Sport mode on R, if I remember correctly.
Pricing I used to come up with the $1940 is using Rock Auto Struts and Shocks, then IPD Bushings (8 total), top bearings, IPD springs, alignment and Sum Calibration/Software update.
I use sport now for my daily commute, comfort mode for when my wife and kids are with me on the interstate. I would be ok spending the extra $400 if I could be assured that the 4C system would satisfy my needs, I am just concerned reading so many "problems" with "crashy-ness" with 4C that I am leary to further invest in that system when I have devised what I think is a good alternate system and hence my question as to others experiences with 4C or Bilstien.
I did follow your thread (nice!) so am I correct in saying that you are still not happy with the 4C system in your S60R?
Yes, the IPD springs will lower the car a bit, but frankly, my car sits a bit low already and appears to be comparable to the photographs I see - I am assuming that the springs are getting a bit tired.
...Can the 4C system be made, though new bushings and springs and software updates, to perform very well?
The problem you run into here is that suspension feel is very judgemental. What feels good to one driver will be like garbage to another; especially in the company of car enthusiasts. Having said that, YES 4C can be made to work quite well. IMO :D
... The ability to switch is really pretty addicting...
+1
I switch modes steadily. Can't do that in most cars.
#13 ·
+1
My perform very well means anywhere near the ride and handling blend of my past cars: G8 GT and 335 - reasonably quite, yet taught, yet compliant... Not the crashing and giggling that I am getting now. The giggling I am certain is a strut that is nearly completely worn. The crashing I would imagine is from worn bushings, but have read so many negative postings on the 4C system I get worried. At least I have one (yours) vote that 4C can be a "good" system.
Any others willing to stand in and have experience with good cars...like any recent BMW 3 or 5 series, Pontiac G8, VW CC...trying to think of other cars that had a good blend of nice ride, controlled handling and reasonable impact noise control.
I like 4c and don't think I could live with out it, but the Bilsetins are nice because they have a lifetime warranty. That means that If you drive a crap load and wear em out Bilstein will rebuild them.
can you go into more depth ?
I am looking to refresh my suspension at the end of the summer and have been in the debate between replacing the OEM parts (monroe struts) vs. going with KW coilovers
#12 ·
More depth...I thought I was killing this already with detail.
I basically priced out rebuilding my suspension with all of the common bushings that wear, then looked at 4C, Bilstiens, KW, and Koni. The KW system adds a lot of cost and I just can't justify spending the extra cash, I am already between $1500 and $1900 - going with the KW would put me $2100, dare you say it is only another $600 for the KW's, but I have my eye on the IPD engine tune.....
Not sure how much more specific you want me to be in the details of my problem and possible solutions.
Just an update on this thread, as it looks like I am going to move forward with the Bilstien setup.
1) I have sucessfully deleted the front 4C struts from the computer by placing a 8 ohm 50w cooled resistor in place of the strut coil - so far no warning light.
2) I contacted Bilstien US - their service people and they will cut into the bottom of the rear shock a snap ring groove so I can fit in a Bilstien rear spring perch : http://www.summitracing.com/parts/bsn-b4boa0000117
We'll see how it goes....
#19 ·
Really? You're going going to go there?
It sounds to me like I'm not the one here that is a poser. Because I don't drive around on the street like a boy racer every where I go in my 4000 lb station wagon?
My username isn't Spin All 4 because I though it would be "ironic"...
I just think it's stupid to go all out on the street where you never know whats going to happen. I take it to the track when I need to.
:thumbdown:
#20 ·
Whoa buddy not saying your a poser just saying that I hate the people that try to race to get in front and then go slower then everybody wants to go. How about get in line just like everyone else. The BMW comment is because that's how most BMW drivers are.
#21 ·
Hey - lets all settle down and focus on finding a solution to the 4C conundrum...driving styles aside.
If I could be assured that new 4C struts/shocks and bushing could solve my issues, I'd jump at it, but I have read about way too many problems and if one did blow out in even 30K miles, the replacement cost, even at Rock Auto, is ridiculous...
#23 ·
^ This LOL!!!
#25 ·
Stoker, you mentioned in a PM that you were going KONI, yet you specify Bilstein in this thread.
How do you go about solving the issue to the shock vs strut conundrum?
Id love to replace my rears with items other than sachs or monroe 2.5T AWD rears. Perhaps something tighter while being able to retain my Eibach rear springs.
#30 ·
If you have doubts about the factory setup, confirmation bias will make you regret returning to stock. Going with aftermarket will save you money and you don't sound like the kind of enthusiast who cares about 4C anyway. For you, delete and forget.
My $0.02
Sent from my SCH-I605 using Tapatalk
#31 ·
My $0.02
Or it very well could be that the overall construction of an OEM strut that fits the R platform is indeed a better alternative than the needle dick shaft of the 4C struts....
