V60 panoramic roof sun curtain behavior, is this normal?
3.3K views 13 replies 11 participants last post by  Gary23x
#1 · (Edited)
Just got a 2020 V60 and I’m wondering is this is normal? When the roof’s sun curtain is closed, a portion of the white leading edge is still visible? Is that expected, or is it not properly closing all the way?
I've noticed some weirdness with the shade closing in my car. Occasionally it does that, comes forward (not holding switch, just tapped for auto close) and then backs off to the vent position. It was doing that consistently until I brought for service and they fixed a stuttering when closing issue on the glass panel. It has been working correctly since except for every once in a while it closes then backs off. I never hold the switch, just a tap to close the shade, so I assume something in the electronic control but it doesn't happen often so I haven't addressed it.
As an aside I have noticed with up to date software you can now close the sunroof along with the windows with the remote or by holding your finger on the door handle lock sensor. If you keep holding it will close the shade too.
It seems to be a common software issue where the sunroof shade losses it's memory as to what position is "closed". This causes the shade to attempt to auto close all the way, become confused, and open back up part ways. This is easily solved
Simply calibrate the sunroof and shade to "relearn" the positions of open/closed/vent. Close the sunroof and shade all the way (if the shade doesn't fully close or re-opens part ways that is ok). Pull the button down as if you are opening the roof manually, but NOT all the way past the detent position that initiates the "auto open" sequence. With the button pulled down, hold in this position for 40 seconds. It seems like a long time but....the roof and shade will move to all positions and relearn fully opened and closed locations. When the calibration sequence is ended, release the button and turn off the car. New parameters will be stored and the shade should fully close and stop now automatically.
I did do the calibration on mine at one time and it did clear the sunroof issues and set the shade back to good. I did end up needing them to do the TSB to fix the stuttering though. But last time I mentioned that re-calibration here I got smacked down by some others here because we are all going to ruin our cars relearning auto windows and sunroofs instead of taking it to the dealer... so I'll keep my mouth shut, oh I guess it's too late for that ha
