Here is the TJ I was talking about. Not sure if it can help my 2-1 shift issue. I wonder if they incorporate it in the latest Total Upgrade. If so, it didn't help me.
Technical Journal
TITLE: Rough shifts, 5-4, Neutral Control, N-D TF80SC/SD
REF NO: TJ 29078.14.0
ISSUING DEPARTMENT: Technical Service
CAR MARKET:United States and Canada
PARTNER: 3 US 7510 Volvo Car USA
ISSUE DATE: 2017-02-06
STATUS DATE: 2017-02-13
FUNC GROUP: 4370
FUNC DESC:Automatic, transmission (hydromechanical
DTC Diagnostic Trouble Codes
Control Module TCM
Code Fault P089500
Type Intermittent
TCM=Transmission Control Module
SW=Software
VIDA= Vehicle Information and Diagnostic Aftersales
*NOTE! THIS DOCUMENT SUPERSEDES THE PREVIOUS TECHNICAL JOURNAL 26840
DATED 19-Aug-2014. PLEASE UPDATE YOUR FILES.
*TJ29078 replaces closed TJ 26840
*TJ updated to include labor op in VST format
DESCRIPTION:
Due to internal tolerance deviation in automatic gearbox (TF80SC/SD), the customer may experience
rough shift from 5:th to 4:th gear, or/and shift shock after standing still at brake release, or/and harsh
engagement N-D shift.
DTC TCM-P089500 might not be stored even with above stated symptoms.
PRODUCT MODIFICATION:
A modified TCM software with better adaptation functionality for internal tolerance deviation in
automatic gearbox.
Adaptation temperatures areas is 1=40-65, 2=66-73, 3=74-81, 4=82-89 5=90-110.
With this SW the adaptation is active from 40°C, for N-D, 5-4 coast down and Neutral control.
MATERIAL RETURN:
Material for analysis can be requested in Vehicle Report.
VEHICLE REPORT:
Follow the guideline found in TIE under Instructions - Manuals, chapter 3.5.3.
Yes, please submit a Vehicle Report if the service solution described in this TJ has no effect.
Use concern area "Vehicle Report" and sub concern area "Support Needed", use function group 4370.
In report please include detailed customer complaint as well as driving condition when it happens.
Which gear, throttle, gearbox oil temperature, driving pattern just before the issue occurred, etc.
Perform a readout with VIDA (if possible, just after issue occurrence) to automatically record adaptation
parameters for further troubleshooting purposes. And add VIDA logs in to VR.
SERVICE:
In case of customer complaints matching above symptoms, update to the latest TCM SW from VIDA.
After TCM S/W update, an adaptation process should be performed.
Use VIDA TCM advanced menu to activate the "adaptation mode" (this will allow you to see which
gear you are in and also when gearbox has been adjusted).
Adaptation has to be performed in specific temperature areas reached by following a specific
HEAT-UP PROCEDURE:
To avoid internal damage to the transmission, it is NOT allowed to heat up gearbox by using brake
and acceleration pedal in D.
To heat up the transmission, start in manual mode with third gear and accelerate with high
acceleration pedal.
Do this until you reach few degrees below target temperature area. Stand still in D mode and wait for
temp to increase to the lower limit of the target temperature area.
Note: For most efficiency for all new functions it is important to reach temp above 85° C.
HEAT-UP transmission until 72°C (refer to above procedure)
STEP 1 - Temperature area 3 (74-81°C):
1. With brake active, put shifter in Neutral, wait 5-10 seconds
2. Move shifter to Drive, brake still active, wait 45-60 seconds
3. Release brake, do not push accelerator pedal
4. Brake the car to complete stop, wait 10 seconds with brake still active
5. Repeat step 1-4 one more time
HEAT-UP transmission until 80°C (refer to above procedure)
STEP 2 - Temperature area 4 (82-90°C):
1. With brake active, put shifter in Neutral, wait 5-10 seconds.
2. Move shifter to Drive, brake still active, wait 45-60 seconds.
3. Release brake, do not push accelerator pedal.
4. Brake the car to complete stop, wait 10 seconds with brake still active.
5. Repeat step 1-4 at least 10 times.
6. If possible, make a test drive to verify the general shift quality, especially for 5-4 coast down shifts.
Note: Inform to the customer when the car is returned, that some hard shifts might occur sporadically
in specific conditions (even several weeks after dealer adaptation - depending on customer driving
pattern). The adaptation will continue to improve the shift quality.
Note: If the adaptation is done in other temperature areas than in above procedure, the shift quality for
N-D, 5-4 coast down and Neutral Control may be more improved.
