TPMS missing
6.3K views 8 replies 7 participants last post by  2005_V70R
This will seem like a stupid question. But I am going to ask it anyway.
I just got my MY19 S90 T6 Inscription less than a week ago. I bought it out of state and drove it 800 miles home. Before I took off I did the car status and checked the tire pressure. My rear drivers side was red.
In my MY08 S80 all I needed to do was check the pressure and start the car and the light would go out. So, that is what I did. I checked the pressure (it was fine) but the light didn't go off. I have since learned the procedure of over-inflate slightly, run the check, deflate back to proper pressure and done.
Ok, I'm getting to the question, I promise.
I am near Chicago and this car came with summer tires on 20" wheels. So, that is my first order of business. I am changing to 18" with Blizzak for the winter months. I sent an email to my dealer and asked if there was anything I needed to do with the computer or TPMS system. This is his response:
I spoke with one of our technicians and your vehicle doesn't actually have TPMS sensors. According to Volvo, as long as your are not going to 21" wheels, the vehicle doesn't need and reconfiguring.
So I am confused. What tripped the tire pressure light? How did adding air make it turn green again? Where is my TPMS system?
Yes.
This is a new type of TPMS system which relies on monitoring the rolling diameter to determine adequate inflation.
it's called "Indirect TPMS". You can read about it here.
It has both advantages and disadvantages compared to direct TPMS.
Drawbacks:
Unlike direct TPMS it cannot give you the tire pressure in measured units.
System needs to be "calibrated" when wheels are changed. You fill the tires to the proper spec, press the calibration button in the vehicle screen, and it uses the next several miles of driving to calibrate the rolling diameter.
Benefits:
Less unsprung weight in the wheels.
Easier to balance wheels with new tires
Less cost.
Never have to worry about TPMS communication issues again.
Some like one, others like the other. I am mostly indifferent these days.
I have had issues with the indirect TPMS on my 2017 V60. When heading out on a long interstate road trip, the tires will naturally heat up and the pressure will go up by several psi (natural gas law and all that). Because the car does not carry the same weight front and rear and because power is going to the fronts only, the fronts will heat and expand more than the rears, causing a difference in tire rpm front-to-rear. So, 200 miles into the trip -BING!- the light comes on.
The choice is to either equalize tire pressures or re-calibrate the system to the new pressures.
By the way, I ran across a page in my 2020 V90 owner's manual that specifically states that you should reset the system whenever you change tire pressures, and that would certainly apply when you change tires. It's a menu choice in the My Car folder, I believe. Check your manual.
you should probably take your car to a dealer to get the indirect TPMS checked out or something else - either your driveline or even alignment. Both direct and indirect TPMS only throw an alarm when the perceived pressure difference exceeds a certain threshold (for indirect this is proxied by rotational speed differences) - typically a real or indirect pressure difference in the 20% - 25% range. If your car front/rear Tire temp differences are wide enough to throw an alarm, either there is something wrong with the system, or something wrong that is causing your fronts to heat up so dramatically different than your rears to throw an alarm.
Yes, you should always recalibrate when you replace your tires. Also, it helps to check all tire pressures when you have to inflate one tire so that you can more accurately ensure the differences actually exist between tires.
I have an issue where the same wheel always seems to lose air, even after mounting new tires to that wheel (not a puncture issue). When I check the pressure, it is indeed lower in pressure than the other tires.
