I have a 63 122 (b18, dual su carbs) that was running like a champ until it wasn't. It was quickly apparent that the fuel pump gave as the pin that holds the arm against the camshaft was missing and all that stuff was loose in there. So I figured after 60 years of service, a new fuel pump was not an excessive purchase!
Got it from CVR - the correct, glass bowl design, confirmed by the sales rep - but now when the car starts up gas is spewing from above the first float bowl where the gas line goes in. checked all the hoses and connections, took both floats out, cleaned and checked them (rebuilt recently) seem to be working fine but I can't run the car without a LOT of gas gushing from the where the main fuel pump line meets the first float.
It appears the new pump is just too strong! My understanding is the pump only pumps when the system calls for it but this appears to be pumping all the time. What did I do wrong? Is there a way to adjust the pressure at the pump? (I sure don't see one). Was the carb tuned to an old pump that wasn't working right and now some major adjustment needs to be made?
Thanks,
Tim
Thanks,
Tim
