Guys - going to take the new car in soon for the 10k.. Should I still have them rotate the tires? Or is it a longer interval?
Why would you put you fresher tires on the rear? They should go on the front to even out the wear, plus to get the best performance. I did see Volvo's TSB of not rotating to leave fresher tires on the rear to prevent oversteer, but it is really one of the dumbest things I have ever read.I "rotate" when I swap winter/summer tires. Basically I always put the tires with more tread on the back because the fronts wear faster due to braking and cornering (suspension setup for understeer) putting more load on the fronts.
We bubbled a tire at 25,000 miles and were told by a dealer that as long as the other side is 6/32 or more its fine. I believe them because I didnt know (the internet and tire shops have vastly different opinions) and they could have sold me 2 without me questioning it. We ran it like that for 20,000 more miles with no problems.How do different tire sizes or dimensions affect the Haldex coupling? The Haldex coupling's mission is to reduce the slip (i.e. the difference in rotational speed) between the front and rear axles. Some slip is always present. It could come from driving in a curve (in which case the wheels have different paths and thus rotate with different speeds), from driving forces being applied differently on the different wheels, from a tire losing its grip and starting to spin, or from different tire sizes. The control strategy in the Haldex coupling accounts for those differences and applies the correct torque level so that the slip can be reduced to an appropriate level. Too large a difference in tire sizes could be harmful to the coupling hardware and could also affect vehicle drivability in a negative way. In those cases, the coupling will open and no longer transfer torque to the rear axle.
Source: https://www.borgwarner.com/en/Haldex-AWD/Pages/FAQ.aspx
So you shouldn't be able to do any damage to the AWD system, but it may disengage if there's too much of a difference.
I've previously seen people saying 4% is the maximum difference in diameter Haldex can handle. If that's accurate, you really shouldn't need to worry about differences in tire wear.
Total height of a some wheel and tire configurations used on these cars...
235/40 R 18 ... about 645mm
235/45 R 18 ... about 668mm
235/40 R 19 ... about 670mm
Even if we use the smallest one, the 235/40 R 18, 4% of the total height would be over 25mm. Even if it can only handle a 4% difference in the radius, that would be 12.9mm. So unless you're using some crazy tires with original tread depth of more than 12.9mm, you should never have to worry about this. For reference, the original tread depth of the Pirelli's on my car was 8mm.
Keeping your tires properly and evenly inflated will help, too.
Goodbye if that is what you really want(you've threatened it multiple times already) but it's not what anyone asked for. If you haven't noticed, everyone is getting along except you. We all disagree on things, but we get over it and don't continue to bicker. You just sound like a whining baby. Why is it that everyone else can have a discussion without getting into name calling our bickering but with you it gets to that? As tarrbot said, time to look at yourself. How long ago you joined this site has zero bearing on the conversation of how you treat people.I'm out. You want to sit around and kick mud in the face of folks that have been here since the inception of this site, have at it You want to disregard the comments of current Volvo employees? have at it. You want to disregard the years and years of first hand experience of Volvo technicians and service advisors, have at it. But you don't disregard them....no, there is no polite back and forth. There is no conceding to just "agree to disagree".
No, it's all personal attacks. It's private messages with mean comments and foul language. It's punch you in the face, drag out fighting, lecturing on internet forum interaction. It's a "prove you wrong at all cost" contest....on a subjective opinion. It's every comment you make construed in the worst possible way and in the most impolite "tone" possible. If there is 95% fact laid out, and 5% opinion, then the 5% is believed over the 95% facts. Oh, you worked for Volvo? Oh you know Volvo management? Oh you have traveled the world for Volvo professional training? Oh you have been to the factory? Oh you have drive the test tract facility? Oh you helped Volvo instigate safety campaigns and product improvement programs? Oh you work with Volvo technicians that have been Volvo-exclusive techs for over 40 years? Oh........you must be a fanboy then and in know way could possibly have more insight and experience than the casual Volvo owners. How dare you suggest real life experience could mean perhaps one should consider your comments to carry a little more merit than a casual owner!!!
There is no winning here any more. Some of you just showed up a few months ago and ran veteran posters off and turned this site into something that isn't enjoyable or fun. You made this a place to fight about Volvos. How ridiculous. Am I the only one to notice all of the folks that have posted a few hundred times seem to have suddenly chased off all of the folks that have posted thousands of times? Even the Moderators are pissed off and don't interact here like they used to....they just are ganged up on at every possible time.
You don't like my attitude any more? Well guess what.....you are probably the one that mercislessly beat me up and sent those private, foul-languaged private messages to me that changed my attitude. Yep, my attitude changed all right. And you have the guts to tell me that it's my fault? Trying to tell someone they praise at work for exceptional customer interaction needs to learn better interaction etiquette is just enough to make me leave here. I'm not concerned with a snarky comment or two towards some of you foul-mouthed idiots, and it certainly doesn't mean I need better etiquette.
Congratulations. The jack asses win again! Another long-time poster has been chased away. I'll have to find a new hobby, as bickering about Vovlo's is certainly not my cup of tea, nor sorting through private messages from posters on this thread with four-letter-word hate mail. I'm sure you don't care to see me go, but perhaps you might consider what will happen to this site in a few more months if something doesn't change. If you chase away everyone, who will you berate next?
I'm officially out.
