Momentary power lapse: the car experienced the problem whilst I was test driving with the engineer but he didn't feel it. I guess if it's not your foot on the accelerator the lack of power doesn't feel like anything unusual. Once the problem is dependable I'll have them drive it for a day or two.....
Question for you - how were you doing the test drive to show the problem? I also get the "can't replicate" from the dealership, but, my car had a problem - and, after reporting it quite a bit, they finally found a problem (when the stalling became much worse and more persistent)… ERAD was replaced. But, it's one of those issues where it may not throw an error until it gets worse, however, as a driver, you can start to feel that there's a problem since the vehicle starts "stalling" or hesitating.
In the beginning, it started when I would accelerate from a stop, after being in Pure, but, switching to Power before taking off. It wouldn't happen all the time. But, when it did, it was scary to see the car roll forward for a few car lengths before finally accelerating. Then, it would do it even if I had been driving in Power mode (however, this may have always been the case, since I spend most of my time in Pure mode). My vehicle has plenty of other errors and problems, but, it all started with the hesitation and stalling, so, try doing a few accelerations from a stop, or, however you've seen the problem occur, and, if you can, make a recording (have someone help you, or, use a dashcam).
