My partners V50 is at 190k miles, I gave it a major refresh at 150k including PCV, timing belt, oil pump, water pump, cam seals and everything to do with that process. Over the last few oil changes I have been seeing a little bit of "forbidden glitter" in the filter. Today I noticed a rhythmic knocking that only occurs under load and matches the engine RPM. I'm fairly certain its rod bearings so my question at this point is can I feasibly do the rod bearings by just dropping the oil pan or is there going to be too much preventing me from swapping the rod bearings preventatively.
I have had a few of these motors apart entirely but In the interest of saving downtime I am hoping to not drop the entire motor.
The wagon is showing its age but I have put enough money and work into it that I don't think its worth letting it die, my concern with only dropping the pan is if I then notice more components that need replacing then it would be partially disassembled, undrivable, and not worth saving the motor. Spending under $500 on parts seems worthwhile; dropping the motor, taking the head off a good compression, non leaking motor and separating the m66 and transfer case would border on untenable. Even with a good power output T5, 6 speed AWD and dynamic package, this V50 is getting closing in on 200k and the car shows it.
