Hi,
How do i know if my tcv is bad?
Okay, sounds like something easy to try for now. I wish your screenshot was in English or Hebrew - what are your codes saying so I don't have to look them up? Interestingly enough I think I can also get a good idea about where you are in the city based on the RussianI tried to disconect while the car runing, i saw the rpm go up from 770 to aroind 780 and then go back to 770 idle... how the car should drive without the maf? The boost remains the same...
I will try to clean the maf today and update then.
Another issue i noticed, today i drove 100 km and i did some pulls (highway), when i arrived to the city i saw that my boost jumped to around 9 psi almost as it should. When i parked the car for 20 minutes and started it again the boost returned to 6.5~psi. What is wrong with the car??
Problem:
When I first start the car, it runs great with full power as if nothing is wrong.
However, after as little as 5 minutes of driving it goes into 'limp mode'.
When I am at a stop, I can put the pedal to the floor, and the car accelerates like an old Dodge Omni pulling a trailer. This loss of power persists until I turn the car off and back on again. While driving, if I need to pass or keep up with traffic, I just throw it neutral, turn if off and back on while coasting, put it back in drive and it runs with full power again for a little while.
