skid plate screws
1 reading
8.8K views 7 replies 7 participants last post by  AutoGeek
Anyone know the size of the screws on our skid plate.had to get a new one and Volvo was gracious enough NOT to add them with a new skid plate.. Called the dealer they didn't even know. thanks in advance.
The OEM splash pan (it's not actually a skid plate) uses seven T30 (Torx) corse thread screws.
The IPD skid plate (it's actually a skid plate) use three M8 bolts in the front and two M10 bolts in the back. (the 8mm are a bit too big for the slots so they have to be hogged out a bit - 7mm would fit fine)
Anyone know of a good replacement for the plastic inserts where the splash cover screws into?
When I ordered the new shield, my dealer was also kind enough to soak me for $2.37 each for new plastic inserts, mine were loose also from years of removal/re-installation. They were listed as a nut, part #30683256. FYI, on the parts computer screen the screws and plastic inserts are shown as bolts with washers and metal nuts, but when he pulled the parts with the same part numbers they were actually the correct inserts. Screws are a coarse thread T30 screw.
