When I got my '66 wagon a year ago I inspected the brake system and everything looked good, pads/rotors/drums/shoes were in all good order. Previous owner had installed stainless flex lines, pedal always felt good and stopped fine. However the car would pull to the right a little under braking. After replacing bushings/ball joints and an alignment, it still pulled to the right. After a while I noticed that the right front wheel was always dirtier, however the left pads were wearing faster. Suspecting mismatched pad compounds I picked up a set of $11 pads for a 240 that dropped right in. After a quick break in no more pulling. Great problem solved.
Well in the process of doing this I noticed that the pedal would get softer and softer as I drove. But I was no longer driving like a normal person but repeatedly braking hard to test the system. Ordered a new set of pads/shoes from VP with proper 122 parts. System was heavily bled and only saw clean bubble free fluid. After a breaking things in and repeated drum adjustments I get the same thing. When I first start driving the braking engagement point requires little movement, but as I drive more the pedal gets softer and softer. When things first start to get soft I can pump the brakes a little and things stiffen up but after even more driving even that results in a squishy pedal feel.
I freely admit I am now really pushing the braking system so I could very well be just getting things hot and experiencing fade. Is this normal?
As things are super stiff when cold I don't think I have any air in the system. There is 0 fluid loss so I have no reason to think there is a leak somewhere. I am just worried that now I have been really jamming on the breaks that I could be causing my master cylinder to begin failing.
