Going back to basics for a minute:
1. Was your vehicle built for the US market? I assume yes.
2. Are your base road road maps set to North America? Likely yes if #1 above is yes. If your car came via OSD, it could be worth confirming and those who had OSD vehicles may wish to comment.
3. What is your Home region and is it set accordingly in Sensus? Go to Map Downloads, click on your desired home region, and “Set to Home Region” if not already checked.
Other Info
1. North America is the base map for the continent. That is the way it is and has been. There currently is no US only subregion or lower 48 US subregion - only geographical subregions.
2. The North America base map is currently v1356 (Sept 2021). There is an estimated base map update projected for 31 Jan 2022. The lack of this base update keeps the map version at v1356. The new update should [emoji1696]fix this issue.
The subregions are most current at v1363 (~11 Nov 2021).
3. If road map updates are not installing, a dealer visit may be needed. Be aware though that I did this very thing in Dec 2021 and all the dealer did was to take a USB stick and install my home region which fixed my home region but it did not fix the inability to install other maps and Volvo third party software apps. I am going back in Feb. to investigate and resolve the purported “No connection to internet” error. (It does have an internet connection for VOC purposes.)
4. [Edited] The latest Voice Control update (Nov 2021 reportedly in US) should be installed to hopefully force the road installer to work and not pause. It has been a solution that worked in the past.
Download the Latest Voice Control files
Voice Control is a small file but it must be the only file on the boot directory of the USB. (If using MacOS, I delete files in Trash to insure that the USB is clean.)
Voice Control install does not have many progress indicates and can take a few minutes to start and another 5-10 to complete the install. Be patient. Ignition must be on - at least mode 1.
See post 1 for a summary for software updates at Latest Sensus Road Map and Voice Control Update Info
