So I've been looking at what fluids I should change with my recent purchase of 2007 S80 3.2L FWD and upon reviewing Volvo's maintenance schedule don't see where the factory fill coolant is to be replaced - EVER. Most all the coolants I've seen are 5yr/150K mile type fluids if they are considered "long life" but with 7 years and 171K miles, I'm thinking I should do a DIY fluid flush pretty much now. Any comments, concerns, recommendations??
How to do:
So my method would be to warm up the car to get the thermostat open and using the radiator petcock, drain the old coolant/water mixture out and replace it with fresh distilled water. Get it warmed up again and repeat this about 4 times (with the heat on high to open up the heater core loop). On the last drain out, I would replace with the HOAT type Zerex G-05 50/50 coolant mixture.
Using this:
http://www.valvoline.com/products/brands/zerex/antifreeze/42
I would rather use this than the OEM HOAT Volvo coolant due to price more than anything else.
Why would Volvo not put fluid replacement in their schedules?
BTW: I was one of the "unlucky few"
that had a 2000 GMC Jimmy with old Dex-Cool in it (I bought it used also) and it had been eating away at the intake manifold gaskets (due to it turning acidic with age) that caused a major and sudden leak into the oil sump and causing badly spun bearings (even with me running M1 oil) in only a few miles. Turned my Jimmy into a hunk of junk. So I'm motivated to clear out the old and in with the new as far as coolants are concerned!
How to do:
Using this:
