S60 2012, 78K miles (125K km) - tranny issues, please suggest
1.5K views 8 replies 8 participants last post by  Tech
Hi,
I have an S60 2012, 78K miles (125K km) on the US roads.
I've started noticing transmission issues - some kicks and occasional late shifting up&down (as a reaction to gas pedal press/depress), especially on a colder car, and even worse when moving in heavy traffic (start/stop). Less noticeable on a warmer car in free highway traffic. I don't yet see some more serious issues like slippage etc.
I don't think tranny oil has ever been changed.
At that point, what should I do?
  1. Try changing the fluid - are there good chances it might help? Are there big chances it'd just make things worse right there and I won't be able to leave
    the place where fluid change was done?
  2. I know there are some US companies selling rebuilt/remanufactured transmissions (in a professional factory-like environment)
    but I don't see them selling TF-80SC's, only "Valve Bodies"... There are however some low-mileage used units being sold.
    What is the typical path for US-based Volvo owners in a similar situation if tranny can't be saved by just the fluid change...
    • Rebuilding by a local transmission repair shop - are these trannies even being repaired/rebuilt at all?
    • Replacement to a used unit?
Thanks!
I'd suggest multiple drain and refill procedures (rather than a tranny flush) before you take more dramatic measures. You'll find useful DIY videos on YouTube. I noticed an improvement in drivability even on our low mileage '16 XC70. Not sure if it's appropriate for your model year but the Level 2.0 software update on our car was transformational. Good luck.
Reactions: BenjaminD
You don't need a lift to change the transmission fluid. Ramps will work just fine. Or driving onto some lumber. I've even driven onto a low curb once in a pinch (had to get under my car at a hotel this one time).
Drain and fill x3 (after driving a bit between each cycle and going through every gear) very likely will not make things any worse the than your current situation. A "power flush" could make things worse so avoid that. Start with the simple things first before jumping straight to replacing the transmission. I'm sure others could comment on transmission replacement, but don't assume you'll need one yet.
owns 2018 Volvo V60 T5
Reactions: MoveZig
What this person said. 3x drain and fill as your would on a Honda/Acura. And never have a "flush" done by one of those machines. If you are not mechanically inclined, talk to your mechanic so they know what you want to have done. Should not be something they question as it is a fairly common procedure especially if they service Honda/Acura vehicles on a regular basis.
Yeah try the drain and fill. It’s really straightforward to do on these cars. You don’t need a lift at all to do it. Just need a level surface so you can properly set the fluid level.
If you have a slanted driveway (like I do) you can just ramps to make the car level.
You’ll want to reset the transmission overheat counter though. If you don’t have VIDA then a trip to the dealership will be needed (where they can also do the other service update if you haven’t done it).
I’d def do those two things before going for a replacement. You won’t do any more damage to it and it could solve your problem.
Not to worry! These are common P3 transmission quirks.
From what I've heard ...
1.) Drain-and-refill cycles
2.) Software update
3.) New valve body
Never have I heard (at least on Swedespeed) of an entire Aisin transmission needing replacement.
owns 2012 Volvo XC70 T6 Platinum
