Update. This problem is SOLVED since April 2024
I have been aware there is still activity in this thread discussing the defect electrical waterpump.
The root cause is known and it is due to a defect batch of waterpumps.
I got my defect water pump installed in October 2023 and it was replaced with a good in April 2024.
Since then everything works fine.
If you have this issue, just replace the pump with a working one.
I have an issue with the water pump. It does not start every time I start the car. When this happens, I need to turn off the engine and wait a few minutes or disconnect the battery cable for some seconds before I start again. I suspect the relay to the water pump is broken and hangs in the wrong state. Does anybody know which relay that gives power to the water pump? It is a 2016 v70
