Rear Fog Light
12K views 18 replies 15 participants last post by  PM55
New 2020 AWD Inscription owner. First of many questions I'm sure. Steep learning curve on this vehicle.
Just need to confirm that the rear fog light is on the drivers side only. If so, what does the same light on the passenger side do? Doesn't seem to light up with anything I've tried.
Fcruise, The rear fog light switch is on the left stalk BELOW the front fog light switch. As stated above in the US, only the driver side is illuminated.
But Volvo is very inconsistent.... on XC40s in the US, there are rear fog lights on both sides: https://forums.swedespeed.com/showthread.php?598433-Rear-Fog-Light
My theory is that if a car has a rear fog lamp on either side and they are near the brake lamps it would be easy to not notice when the brakes were applied. The xc40 has two but they are mounted down low in the bumper.
And as another poster on this forum said " Think of them not as "fog lights" but rather "high conspicuity" lights for conditions when you need to make your vehicle more visible/conspicuous to other drivers. Fog is one condition; but also heavy rainstorms during the day it can be nearly impossible to see normal/non-braking tail lamps until you're right up on a vehicle. Heavy snow showers day or night. Dense smoke. Pyroclastic flows from a volcano..."
#17 ·
Interestingly on your XC40 have the same lights in the same position
Of course they bother when used in normal visibility, it's the same when some car comes from the opposite direction and use the high beams. There are stupid drivers all over the world.
In most EU countries, this is punishable by law
What is the point of your post ?????
