Chinese clone
ETM sweep procedure works just fine.
2010A works with Windows XP Pro SP3 and Vista
2010D works with Windows XP Pro SP3 and Windows 7 Pro. (does NOT work with 64 bit windows, except, supposedly, in 32 bit compatibility XP mode)
I have VIDA 2010D as well running on XP Pro SP3.
Haven't yet figured out how to change seat temperature settings, for instance, or other settings that can be changed at the dealer. Confirm that dealer says SUM is done locally.
To do the software downloads, I suspect you need the very latest version of VIDA, and 2011A ought to be out around very soon, if not already out. No idea if the clone DiCE units are detected or not.
Best way to use it is to simply try to go to different sections of the program. It has the parts manual and service/repair manual for cars since the late 1980's, but VIDA/DiCE combo only works with 1999 or later cars, with ME7.x ECU. You can use VIDA to look up parts and repair instructions for earlier cars, but cannot directly connect to them for diagnosis.
VCT 2000 was the prior device, but even it was only 1999 or later.
VST (Volvo Service Tool) was used for earlier cars, but you connected it to the car, read the car, and then went into VADIS or later into VIDA and listed what codes you fond for that car to trouble shoot the car.
