Hello again everyone.
I also have two other codes:
- P2015: Intake manifold air control actuator position sensor/switch, bank 1 - range/performance problem
- P2004: Intake manifold air control actuator, bank 1 - actuator stuck open
These two codes are correlated because the actuator malfunction (stuck open) naturally causes an abnormal reading from the position sensor. The component involved here is the intake manifold control actuator.
The code I need to resolve is therefore P2004: Intake manifold air control actuator, bank 1 - actuator stuck open.
Have you ever encountered or resolved this issue? With your experience, where do you think I should start? Do you think it might be related to my EGR issues?
Thanks in advance for your advice! 😊
