Car has had a very mushy/spongy brake pedal in the last year or so. Pads were almost gone so I figures it was part of the problem. Rotors were fine.
I took the opportunity to replace the full fluid in the system too as I found it was very dark, and somewhat "gelly".
I see no improvement in the pedal feel at all or braking power. I did notice the front pads seemed to only be making contact with the outer half of the rotors (as the inner half keeps some light rust.
I found no leaks anywhere in the system, so I don't think I have leakage. Bleed and rebled to confirm there was no air. Pedal remains mushy... Vaccuum seems fine and not leaking (electrical pump works well after a few pedal push, won't start by itselft...
Is the master cylinder internal seals the most likely remaining possibility? I'm thinking maybe whatever line is going to the front calipers is somehow not able to get proper pressure down on the pistons and leaking its pressure into the second line? Does that make sense?
