OK guys, I am back for further enlightenment:
About a month ago I ordered a gasket set for what I thought was the M41 transmission in my '70E and dropped them off for the guy at a local shop who's replaced the bearings in it. He got back to the project today and called to tell me that almost none of the gaskets, except maybe the one for the top cover, would fit. I double checked the invoice then called Christer at VP-Autoparts who immediately said that I might have an M410 and that it would be OK to send them back for a refund because he doesn't have the gaskets for a M410. He seems like a genuinely nice guy and I continue to think highly of VP-Autoparts.
I called the transmission shop again and he looked around and did find an M410 reference on the bellhousing, so it seems that is indeed, what I have.
I've seen references to the M410 as a possible swap out for an M41, but hadn't dug into it at all. I thought it was a possible transplant from a 164 but in the little time I had this afternoon to search the net a bit I found a Wikipedia posting that said that for some reason a FEW 1970 1800's were built with the M410. That it's more heavy duty and capable of handling more torque than an M41 BUT that the bearing life is barely that of the M40..... heavy duty, but not as durable
I suppose I could buy them somewhere, but the trani guy said he makes gaskets all the time - it just takes more time of course - so I told him to proceed with making them. I'd also given him a set of gaskets and seals for the J-type overdrive, and they are OK, so I'm covered there.
I guess my questions come down to three:
1) Any idea why volvo engaged in this little experiment? Maybe they had a problem getting some M41 parts for a while or something?
2) What's your reading on the "tougher but less durable" bit?
3) Since I like to have a full set of manuals if possible, and the ones I've downloaded for the 1800 and the M41 specifically don't cover the M410, do you know where I can download that manual?
Looking forward to a long Easter weekend; I hope to spend a fair chunk of it under and in the car putting things back togother - and I have a lot to put back togother at this point.
