I don’t know if this is best practice but I like to keep the coolant level in the reservoir tank right at the MAX mark. In the 5 years I’ve owned my 07XC, once a year I’ve added a small amount of coolant, the level was maybe just a half-inch below Max.
This year I also added a little bit of coolant but I’d say around the fifth time driving afterwards I got a LOW COOLANT warning message when I turned the car off. I checked the expansion tank and sure enough the level was near the MIN mark. I added coolant back to the MAX mark and thought maybe when I did my annual topping up of the coolant, I hadn’t sealed the blue-green cap on tightly and coolant had escaped.
About a week ago I noticed the coolant was below the Max level and thought maybe the cap wasn’t sealing properly so I grabbed the same cap from my 02XC parts car and used that instead. Both caps seemed to screw on fine and I used a lot of force to really crank the caps on tight in case air was somehow entering the system from a bad seal.
I did a couple of local trips around town with no problems but then yesterday, on a longer drive, after about 20 minutes the Red triangle came on with a warning, Low Coolant, Stop Safely. I pulled over and the reservoir looked to be completely empty. The upper heater hose was hot and hard as a rock, I couldn’t squeeze it. I slowly cracked the green cap. A lot of pressure escaped and fluid came flowing up into the expansion tank and even a little passed out the top before I screwed the cap back down. I waited about 20 minutes for everything to cool down, topped up the coolant to max, then drove home.
Thinking I had air in the coolant, I went through the burping process. I ran the car at idle, turned the heat all the way up, and removed the green reservoir cap. After about 20 minutes the car reached regular operating temp and the heat was coming hot out the vents. I shut off the car.
This morning I checked the coolant level and topped it up to Max. I went for another long drive and this time after about 30 minutes the Red Triangle was back with the Low Coolant, Stop Safely message. I opened the hood and it was the same as before. The cooling system was under heavy pressure but there was no coolant in the expansion tank. When I cracked the cap, the pressure escaped and the coolant filled (and would have overflowed) the tank.
This is all new to me, folks. Is there an opening somewhere that’s letting air in when the cooling system is under pressure? Could this be caused by a pocket of air in the system? Though I’d like to think air was getting in through a loose cap, I’m not so sure. I screwed the cap on very tight each time I added coolant. Maybe what I've described is a tell-tale symptom of some bigger issue? I’m going to search the web to see what I can find out then I guess start checking all the connections. Any help or ideas are greatly appreciated!
