Hey all,
I'm in the middle of a full interior swap and wanted to share some pictures I've taken and some things I've learned in the process. I'm doing a swap from tan to black because 14 years of use are showing a little too well. Black tends to be much more forgiving. I'm generally not a fan of beige anyway. In addition, the headliner is also going to be swapped. My car came with a DVD screen and player mounted to the roof and I want them gone. We never use it, the screen likes to rattle sometimes, and it'd be way too expensive to repair again. However, the headliner got huge pieces cut out of it during installation to accommodate the new hardware, so the existing piece is trash.
I acquired a donor car that I'll be pulling everything out of. The seats are pretty faded, the armrest is torn up, the driver's seat is split, and there's all sorts of mystery stains in the back, but none of this is much cause for concern. I'll be replacing the seat cover and armrest the next time a suitable candidate rolls through the local pick-n-pull and I'll be renting a carpet shampooer to clean all of the carpeting anyway. I've also bought a leather dying product that's supposed to fix the faded leather right quick. More on that when I get to it.
So far I've put about two days of work into it and have my car completely gutted. While everything was out, I took the opportunity to run some new wires to the driver's door to hopefully fix the crackling I hear in the speakers as well as install some Kilmat panels to hopefully cut down on road noise a bit. Overall this car is pretty comfortable on the highway but there's room for improvement. After seeing just how much stuff is running all over the place, most of the focus will be on the doors and floor area.
Here's a couple of things that I've learned so far:
I'll post more updates as things progress. In the meantime, here's a photo dump of all the juicy stuff you never get to see under your feet. If there's anything you want to see in more detail, let me know. I'm going to be putting stuff back in over the weekend, but the donor car will be getting emptied out.
With the foam panels removed:
- Prep the dash first. It's a lot easier to pull things like the stereo, vents, dash speaker, etc when there's still seats in the car. There's plenty of spots in the front that you can't sit or stand on, which makes for some very awkward positioning.
- As you remove stuff that's screwed and bolted down, put the screws back in once the thing is out. There are going to be a LOT of screws and you will not remember where they all go. It's a good habit to be in even when doing things like engine work. It takes discipline but it's absolutely necessary in this situation. Alternatively, bagging and labeling works for some people.
- Time. Give yourself plenty of it to do this sort of thing. It doesn't look like a lot, but it's like an onion. It's not until you see the pile of trim pieces that it sinks in just how many things there are that need to be carefully removed. At minimum plan for a full day to strip a car, then another day to reinstall everything. Remember that you have to do this twice (two cars).
- Space! You're going to need a fair amount of space to stage stuff as it's pulled out or waiting to go in.
- Pull everything out of the target car first. This way you get to learn what not to do with the trim pieces you don't care about. Then when you get to the trim pieces you want to keep, you'll know exactly what not to do.
- Personnel. It's very handy to have another person helping you for at least a few spots. Things like the third row seats and dashboard are large and awkward. All of the seats are also of considerable heft, especially the third row. It's possible to do it yourself (as I can tell you firsthand), but having another pair of hands will make your life a lot easier.
- VIDA isn't strictly necessary, but highly recommended. A lot of stuff is pretty self explanatory when it comes to pulling it, but some things haven't been documented anywhere online (that I could find). Having VIDA handy means you'll be able to get it figured out.
- Don't worry about keeping the clockspring centered. When it's centered, it will go about 2 and a quarter turns in each direction. If you get off center, find the spot where you can turn it 2 and a quarter turns in each direction. Just be gentle with your turns and don't force anything.
