How much burble/pop is normal with an aftermarket exhaust?
2.9K views 6 replies 4 participants last post by  SwedishDoomGoblin
Particularly in an '09 S60 2.5T AWD, but really for any 5 cylinder. I have an IPD catback and my exhaust burbles and pops like crazy. Especially when the engine is cold, if I'm driving down a hill at like 2000rpm it'll just burble the whole way down. Or whenever I let off the gas or downshift it burbles or pops, and you can blip the throttle at certain RPM's to make it start popping really loud. I don't mind it, if anything I love it, but I'm just not sure if it's normal
I have a custom stainless 2.5" exhaust with two straight through Magnaflow mufflers on my 04V70 2.4 non turbo. Zero popping or backfiring at all. It sounds absolutely glorious above 5k rpms and it's not to loud just cruising around. I believe the turbo cars will pop on deceleration depending on the blow off valve it has.
Tune is 100% stock, only mods related to the engine/exhaust are my catback. Car was 100% stock when I bought it. I was thinking maybe a leaky injector? Unless it somehow has something to do with my intake since I'm just running an open cone filter. Not sure though. If I blip the throttle at certain RPM's in 2nd, 3rd, and sometimes 4th gear it'll cause some loud pops while certain RPM's in 2nd and 3rd will cause burbles/pops while coasting downhill.
It's honestly not an annoying thing, I absolutely love it. I just wanna make sure it's not harming my car
This might explain why it's more pronounced when your engine is cold:
It could be any number of things, so you're absolutely correct in at least wanting to investigate to make sure there's nothing wrong. Often times its pretty benign though and can be resolved with fine tuning the ECU tune to compensate for your new intake/exhuast setup. You want your engine to run as optimally as possible and work in harmony with how its breathing now, so just food for thought. A little burble and pop is certainly fun and sounds great (like you get on a Fiat Abarth), but more than that and it's worth paying attention to and figuring out.
