Coolant are on the firewall side. Oil is top and bottom.
All banjos on turbo are 17mm head with 12mm crush washers. Drain is 2x t30. Flange nuts are 13mm. The oil supply at the block is 19mm with 2x 14mm crush washers.
TD04 Turbo Swap Parts
Manifold to Turbo Gasket
8642450
Turbo to DP Gasket (angle) (1999+)
8642449
Turbo Oil Return Drain Upper Gasket
31251456
Turbo Oil Return Drain Lower O Ring
31251439
Turbo Oil Supply Crush Washer @ Block (x2)
947621
Turbo Oil Supply Crush Washer @ CHRA (x2)
947282
Turbo Water Supply and Return Crush Washers (x4)
Thick 11994 (Thin 947282)
Turbo to Downpipe Stud (x3)
1357769
Head to Exhaust Manifold Studs x10
982667
Exhaust Manifold Gaskets (set of 5)
271802
Exhaust Manifold Stud Washer x10
419401
Turbo to Manifold, Downpipe Lock Nut x4/x3
977209
Manifold/Head Lock Nut x10
985868
