Hello everyone,
The slow oil leak from my 04 V70 seems to have recently got worse. The leak seems to be isolated on the drivers side though I am not sure if this is a leak from the turbo or the rear main seal (or somewhere else). Here are some pictures of the leak(s):
(looking up at bottom of turbo with some cleaner looking oil on it)
(It was quite wet in this above the green dot where that flat section is, I instinctively wiped the drip before taking a picture :/)
(another angle)
(You can easily see the leaking area after removing the tray)
~6 months ago it was barely leaking any oil and I wouldn't need to add any oil between changes.(though I did notice the turbo inlet was slightly wet similar to first picture but not as bad). Now the oil seems to be leaking much faster. I have bought a PVC kit so I will be doing that job at the start of February when it arrives, however I am passing the glove test and no smoke comes out of the dipstick when the engine is hot so there doesn't seem to be pressure in there currently. Would a rear main seal blow out on these engines if the PVC is okay?
Is there any known methods to determine if it is a rear main seal vs a turbo leak? I find it very hard to see any of the turbo inlet/outlets due to the bevel gear in the way. I will start tearing down the top of the engine later this week to get a better view.
I am not sure what could cause this leak to get worse if the PVC system seems to be okay. Any insight is greatly appreciated. Thanks!
(another angle)
