Is the new XC60 T6 engine accepting lower gasoline grade other than premium 91 octane?
Argh! Whoever started putting a comma before "and" should be shot...figuratively of course.Starting with the SPA vehicles, even the T5 requires 91 octane or higher. In fact, the manual wording has changed to "Volvo demands premium fuel (91 octane or higher) for all T5, T6 and T8 engines". This suggests that they modified the software programming to need this. Pretty certain that if evidence is discovered of neglect of a vehicle against manufacturer requirements, that your warranty would be affected.
What bothers me more with this statement, is that the Harvard comma is missing after "T6".![]()
T5 Drive-E engines prior to SPA allowed regular. The wording was:It isn't because of some software change. It's because of an engine change- the Drive-E being direct injection whereas previously Volvo did not use direct injection.
So I stopped by this particular Sunoco station and it does sell 90 octane, E0 gas. Apparently this is a thing: I had no idea. Now I've gone down the rabbit-hole into a world of ethanol vs. non-ethanol, premium vs. non-premium , top-tier vs. generic. It's all a blur.Says that for me as well
Sent from my Pixel XL using Tapatalk
Just checked the paper copy of the manual for a 2015 XC60 I am working on, and the part about the Drive-E engines requiring 91 is in there.That is the wording they have used for years in the prior engines that did not require 91 (before Drive-E).
I'll admit, I didn't check the owner's manuals right away when they came out, but I do specifically remember when I was in class for that engine and we were told it would require 91. This was before the engine was out. Perhaps they forgot to account for those engines in the owner's manual initially, but it looks like they are updated now.
Interesting. I assume you're referring to the text that states "Vehicles equipped with the high performance 4-cylinder engines (B4204T9 and B4204T10) require premium fuel.". I asked my service desk if this applied to my S60 T5 Inscription, and they said it wasn't affected by this notation. It's pretty confusing when the manual references engine model numbers rather than just stating T5, T6, Polestar, etc.Just checked the paper copy of the manual for a 2015 XC60 I am working on, and the part about the Drive-E engines requiring 91 is in there.
If you have a Drive-E engine, premium IS required. Required. Not recommended.
Failure to use premium can damage a Drive-E engine. Haven't run into it yet, but I'm sure I will in time. I'm curious to see how warranty is handled for someone neglecting the car but it probably won't end favorably for them.
Stop wasting your time.It is openly stated that 91 octane is required. No where does it state that failure to use 91 will not cause engine damage.
Look at a manual from a non-Drive-E car. It says 91 is recommended but 87 will not damage the engine.
Now go look up what octane means, why certain engines require certain octane ratings and the damage that can occur for failing to follow requirements.
I wish there was a like buttonThis thread is beyond ridiculous.
Time to lock it up; in the meantime, you have TWO choices:
1. follow Volvo's guidance
2. save two bucks or so per tankful and do your own thing
